KZ1000J, Cam Chain Life
Re: KZ1000J, Cam Chain Life
24 Mar 2021 09:40 - 24 Mar 2021 09:42Dragging a thread into the 2020's. Is it possible to change out the cam guides with just the top valve cover removed? I have a 26,000m bike with what sounds like a noisy cam chain on low revs/tick over.
I will go down the manual tensioner route but wondering if it's also worth swapping the guides out if easily removeable.
Cheers.
Before replacing chain guide, ( which you should pull the top end off for )or splitting cases for cam chain replacement
Try setting the motor to fully tuned up specs
Motor will rattle if valves are not shimmed properly, Carbs synced , and all adjustments completed first
Last edit: 24 Mar 2021 09:42 by Street Fighter LTD.
The following user(s) said Thank You: Dr_Kiwi
24 Mar 2021 09:42
You do not have to remove the head to swap in cam chain idlers or the tensioner. Extreme caution you don’t drop parts into the lower cases. But to change out the chain you will have to remove the upper end and split the cases.
- zed1015
24 Mar 2021 10:43
On the J/GPZ type motors you have to remove the head and block to remove/replace the cam chain guides.
24 Mar 2021 11:17On the J/GPZ type motors you have to remove the head and block to remove/replace the cam chain guides.
thanks I need to stay within my vintage..
24 Mar 2021 11:45
The short answer is no. Also, the long answer is no.
- Rick H.
25 Mar 2021 04:25
More popcorn please.......
Rick H.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
25 Mar 2021 08:43
By Dr_Kiwi: .... I have a 26,000m bike with what sounds like a noisy cam chain on low revs/tick over. ....
Have you synchronized the carburetors with a vacuum sync tool?
- Dr_Kiwi
26 Mar 2021 09:19
Carbs have been sync'd and are fine. When I stripped,cleaned and rebuilt the auto tensioner I noticed it was slightly outside (less than) the 7/16" 7.5mm they spec in the workshop manual.
I have been told on a number of occasions the chains on the 81-83J's are pretty tough and don't seem to stretch at the millage my bike is showing.
I will try the APE manual tensioner and see if that helps, maybe time for a strip and build at the end of the summer.
Thanks again folks.
Thanks again folks.
26 Mar 2021 14:44
You might want to pull the tensioner and make sure it's working properly before ditching it. Under normal usage the chain, tensioner guides, and the tensioner proper should last the life of the bike. Maybe the tensioner is gumbed up or something?
- Dr_Kiwi
04 Apr 2021 06:06
Just an update as I hate it when a poster just disappears.
ATE Chain tensioned didn't seem to make any real difference, the bike still makes some knocking/slapping type noises when warming up, like said previously they are almost continuous but not rhythmic or directly related to RPM. It almost sounds like a bottom end noise but I'd expect that to be inline with tick over/rpm.
Once warm the bike is fine and even when cold it doesn't sound too bad, I plan on running it this summer (if we have one in the UK) and taking a good look at it this autumn/fall.
Thanks everyone for your suggestions so far and if there's anyone in the Northwest of England who knows these engines inside out please shout up and I'd appreciate to borrow your ears!
Cheers,
Mike.
Cheers,
Mike.
04 Apr 2021 09:36
What is the idle rpm speed set at? Ed
04 Apr 2021 09:44
My 78 1000 will make noise if I lower the rpm to much (below 800) It’s backlash in the trans. If I pull in the clutch it gets quiet. I normally keep the idle rpm about 1000 to 1100
