rehoning
- brianrae33
rehoning
28 Jan 2013 23:45
replacing the rings on my #4 cylinder because i bent the second compression ring..question..barely 500 miles on the rest of the cylinders..rings seated real nice..so should i just deglaze the cylinder thats getting the new rings or would it be beneficial to deglaze all of them...thanx in advance for any input..
1982 kz1000ltd
- wireman
Re: rehoning
28 Jan 2013 23:53
Wouldnt hurt to knock glaze off them,dont get crazy with it though
- brianrae33
Re: rehoning
29 Jan 2013 00:01
so even though the rings are seated pretty much..i can still just knock off the shiny part???
1982 kz1000ltd
- wireman
Re: rehoning
29 Jan 2013 00:25
Yep youre just knocking off the glaze is all.
When you finish honing the cylinder get 2-3 cans of carb or brake clean and a couple rolls of white toilet paper.
Start spraying down the bores then keep cleaning them till you dont see any black crud coming off on to the toilet paper,it may take a while but keep doing it till the bore is clean then do the next one.
As for whether to oil the bores/pisons or install them dry thats a totally differant discusion,I install pistons/rings dry myself.
- steell
Re: rehoning
29 Jan 2013 00:40
I would put the new rings on and run it, 500 miles is nothing unless it's racing miles.
- Old Man Rock
Re: rehoning
29 Jan 2013 07:33
Well hell, you have to pull the cylinder anyways right... Might as well deglaze all 4 and be done with it...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- steell
Re: rehoning
29 Jan 2013 18:57
Here's a novel idea, do some research on the subject. What the honing actually does, how it's done, and the results of the process. If after that you decide to hone all four cylinders, I'll be amazed.
- turboking
Re: rehoning
29 Jan 2013 19:15
since you have the cylinder block off anyway hit all 4 holes with a ball hone . doing that won't hurt anything. if it were mine that is what I would do.......... :dry:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- donthaveakawman
Re: rehoning
29 Jan 2013 19:16
do research the break in period so the assembly lube has time to evaporate.
- Roadflyer
Re: rehoning
29 Jan 2013 20:00brianrae33 wrote: replacing the rings on my #4 cylinder because i bent the second compression ring..question..barely 500 miles on the rest of the cylinders..rings seated real nice..so should i just deglaze the cylinder thats getting the new rings or would it be beneficial to deglaze all of them...thanx in advance for any input..
I would not hone the cylinders that are getting used rings put back in. I did exactly that years ago, turned a good, clean running Z1R into an oil burner. I was told after the fact that new rings have a rough finish on the face of the ring that acts against the rough finish of the honed cylinder wall. in a perfect world the rings and cylinder wear together to create a smooth good sealing surface on both the rings and cylinder wall. A worn smooth surface on the ring face coupled to a honed cylinder finish = a very long time before the cylinder wears smooth and stops buning oil.
If your rings have seated properly why would you take a chance on messing that up?
1979 kz1000 shaftie rebuild project
1045 wiseco 10.25-1 pistons
Kenny Harmon 380 lift cams
- wireman
Re: rehoning
29 Jan 2013 23:06Did anybody notice the part about knocking the glaze off and not getting crazy?wireman wrote: Wouldnt hurt to knock glaze off them,dont get crazy with it though
but hey by all means put the damn cylinder back on the way it sits,dont worry about cleaning the trash out of the bores because everybody knows theres no little pieces of trash that get embedded in the cylinder walls from the rings as they seat themselves when they get installed.
Hell I wouldnt even waste money changing the oil and filter,cuz everybody knows all you need to is add some zzzzzzzzzzzzzzzzdp and everything will be fine! :woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
The following user(s) said Thank You: turboking
- Old Man Rock
Re: rehoning
30 Jan 2013 00:45
Interesting research... I took your advice and came across this... See bold...
Pretty much what the rest of us replied...
The term "honing" includes more than one process, and each process has a different objective.
After cylinder boring, honing is used to smooth the cylinder walls and remove the peaks left by the boring process.
When re-ringing, a hone is used to put small scratches in the bore, to achieve rapid ring wear to seat the rings.
Rings will seat without honing (a used cylinder), it may just take longer. Anyone that tells you that rings will never seat unless you hone, is saying that ring wear will never happen. Cast iron rubbing on cast iron and no wear will happen? Neat trick.
If the cylinder still has all the cross hatching visible, and all measurements are within limits, then why use a hone? The purpose of honing is to put the cross hatching there, right? And it's already there.
I'm still not sure what people refer to when they speak of a glaze breaking hone, as far as I can determine, a glaze is just a cylinder wall that has worn smooth, and in that case you would want to hone the cylinder with a standard cylinder hone.
To answer the original question, you can get a brush/ball/ whatever term the parts store uses, hone from AutoZone or any other parts store, and do a light hone to seat the rings faster. You are basically turning the cylinder into a file to wear the rings rapidly, to get maximum seal sooner.
Just my usual questioning of "Conventional Wisdom"
[Edited on 25-3-2005 by steell]
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
The following user(s) said Thank You: Tomolu5
