Rookie wrench and a head gasket
  • souljur412
  • souljur412's Avatar Topic Author
24 Jan 2013 19:31
#569029
I am a rookie with a 83 GPZ750, have done light mechanical clutch,removing swingarm, etc,,, is doin a blown head gasket outta my range or should i go for it?
  • RTGPZ
  • RTGPZ's Avatar
Re: Rookie wrench and a head gasket
24 Jan 2013 19:39
#569031
go for it, get your engine in the right timing marks on engine and take pic of engine to remind yourself were things go!
old school w/ new look
02gsxr 1000 front forks w/6 piston calipers
06 gxsr 750 rear suspension
6 speed trans out of gpz550
Reinforced frame
  • DoubleDub
  • DoubleDub's Avatar
24 Jan 2013 20:08
#569035
Just remember, the head isn't stuck - there are just two 10mm head bolts in the cam chain tunnel. :whistle:
  • souljur412
24 Jan 2013 20:34
#569042
thankz,,,nice bike by the way.....got one just like her,,,beautiful lines
24 Jan 2013 20:55
#569045
souljur412 wrote: I am a rookie with a 83 GPZ750, have done light mechanical clutch,removing swingarm, etc,,, is doin a blown head gasket outta my range or should i go for it?
Diagnosis of a "blown head gasket" is often erroneous, even by somewhat experienced mechanics, and especially by rookies.
Has any confirmation testing been done, such as --
Spray-powder test?
Leakdown test?
Compression test?
Good Fortune! :)
  • donthaveakawman
  • donthaveakawman's Avatar
24 Jan 2013 21:03
#569047
What??? Have you all been living under Iraq??? you need to replace the head bolts. especially if they are "stretch type bolts" look in your repair manual to see if that is the case. I have seen many a rod thrown due to carelessness of this type. also find a decent torque wrench, and use gloves because of the lead.
  • bountyhunter
  • bountyhunter's Avatar
24 Jan 2013 21:20
#569049
Get a Kawi service manual.
It's doable.
24 Jan 2013 21:34
#569051
For sure get the Kawasaki Service Manual, and before you go pulling out any bolts you need to very carefully identify the symptoms and run some more diagnostics. These bikes don't normally blow head gaskets, so pulling the head may cause more problems than it solves - and cost you money for no gain. Ed
  • RTGPZ
  • RTGPZ's Avatar
24 Jan 2013 21:39
#569053
Lmao, last time I seen a stretched head bolt on a stock engine was-wait for it, wait for it. I can't remember! Wrapping yourself in plastic wrap defeats the purpose of working on bike. Lol . But hey all jokes aside be careful!
Reinforced frame
  • baldy110
  • baldy110's Avatar
24 Jan 2013 21:43
#569055
I have used the stock head nuts and bolts over and over and over and over and over and over again without any issues whatsoever. Save the money and just re-use your stock nuts and bolts. The only time you need to upgrade is if your making a hi po motor. As mentioned get a manuel, be patient and do a lot of reading of the manuel.
  • donthaveakawman
24 Jan 2013 22:15
#569069
replace not upgrade, once they stretch they stay stretched.
  • Motor Head
  • Motor Head's Avatar
24 Jan 2013 22:21 - 24 Jan 2013 22:24
#569076
donthaveakawman wrote: What??? Have you all been living under Iraq??? you need to replace the head bolts. especially if they are "stretch type bolts" look in your repair manual to see if that is the case. I have seen many a rod thrown due to carelessness of this type. also find a decent torque wrench, and use gloves because of the lead.
:blink: :whistle:
Definitely NOT Stretch to Yield Head Bolts. They are Studs. they can be used again, No Worries. UNLESS someone way over torqued them. Then more than likely they would have the threads pulled out of the engine case.
Do a check, as Patton suggested. Make sure of your issue before pulling it apart.
Make Sure you have a copy of the Factory Service Manual. It will tell you how to repair the complete Motorcycle. ;)
Last edit: 24 Jan 2013 22:24 by Motor Head.
