Small Leak Tach Drive Gear
- alparmer
22 Jan 2013 11:27
No eBay APP ID and/or Cert ID defined in Kunena configurationI have a small leak coming from the tach drive gear. I went to take the cable off and the thightening nut broke, so now I need to get a new cable (got one ordered). It appears as if the leak is not from the outer o-ring on the drive gear, but from the inside. Is this the correct seal to get:
Stock '78 KZ650 SR
- KZJOE900
- Admin
Re: Small Leak Tach Drive Gear
22 Jan 2013 12:18
Hi Alpamer, not sure if that is the correct one, you would have to match the number based on what the parts manual says. People here will confirm it for you. But for the price why not consider this from Z1Enterprises - Click Here. Once again, please confirm that this is the correct one for your model. You can always call them and give them your VIN and they will confirm.
alparmer wrote: I have a small leak coming from the tach drive gear. I went to take the cable off and the thightening nut broke, so now I need to get a new cable (got one ordered). It appears as if the leak is not from the outer o-ring on the drive gear, but from the inside. Is this the correct seal to get:
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
22 Jan 2013 12:34
To do the job right you should replace parts 13, 15, and 16 in the diagram below. All three are still active parts, so any Kawasaki dealer or Z1E can get them for you. I did mine 10,000 miles ago and it hasn't leaked a single drop since. Ed
Attachment 00000_2013-01-22.jpg not found
- alparmer
22 Jan 2013 14:09
For reference as to installing the new seal --
Click > www.kzrider.com/forum/2-engine/558813-in...in-tach-drive#558813
The old seal may be encrusted into the tach drive housing.
It's important to get all of the old seal removed.
May entail picking it out bit by bit, with the help of a good light and magnification.
A dental pic or similar tool may be helpful.
- alparmer
28 Jan 2013 18:14
I just got the new seals, but I ran into a bit of a problem. I picked the old main seal out...as much as I could since it was baked in there...and it appears there is a retainer ring (see photo). I also just got my shop manual but can't find anything on the tach drive gear. It looks like I have to remove that ring in order to insert the new seal. Any ideas?
Stock '78 KZ650 SR
28 Jan 2013 19:22 - 28 Jan 2013 19:24
To me it doesn't look like you have removed the seal from the tachometer gear drive yet. The parts should look like the pic below before you assemble:
Attachment tachseal.jpg not found
Last edit: 28 Jan 2013 19:24 by 650ed.
- trianglelaguna
28 Jan 2013 19:26 - 28 Jan 2013 19:27
i think the out seal has ring/spring pressed into a groove in the taller rubber seal...yours being baked it stayed in the recess right...sharp tiny screwdriver....dental pick...freeze it for a few hours???
hay guys is there any way to order just the outer cheap (like 5 bucks ) seal and use some viton or decent orings inside,and not have to buy the metal drive housing...all the seal "kits" show the metal bolted piece and are 30-40 bucks?...does the metal part wear out too...am i being cheap here...mine leaks on everywhere...makes it look like my head is leaking...gets on the pipe...time to fix
www.z1enterprises.com/ItemDetails.aspx?i...Guide&item=PM81-2230
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
Last edit: 28 Jan 2013 19:27 by trianglelaguna.
- alparmer
28 Jan 2013 19:31
Well, that retainer ring was actually part of the seal. I pried it out and put the new seal in without problems.
I got everything installed and when I went to put in the new tach cable...freaggin' heck, the nut cracked again. Last time it cracked when I went to loosen it, now when I was tightening it. I didn't realized they were so fragile. I was tightening it with pliers, and it looks like it should only be by hand. The new cable I ordered was NOS. Now I have two perfectly good tach cables without the nuts that tighten them to the drive gear. What a waste.
Stock '78 KZ650 SR
- trianglelaguna
28 Jan 2013 19:40
i have had that happen too....easy peasy is all i can say...hand tight they can come loose too...i was lucky...i rode with mine before i looked down and saw no rpm's , pulled over and the inside drive wire had not fallen away
hand tight and snug with small pliers?
did you buy the whole "kit" like my link?
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- alparmer
28 Jan 2013 19:51
No, I bought just the three seals, and the cable separately. Now I need to order another cable
Stock '78 KZ650 SR
- alparmer
28 Jan 2013 19:53
I think I'll hand tighten with some blue thread lock.
Stock '78 KZ650 SR
