Small Leak Tach Drive Gear
- alparmer
Stock '78 KZ650 SR
- KZJOE900
- Admin
alparmer wrote: I have a small leak coming from the tach drive gear. I went to take the cable off and the thightening nut broke, so now I need to get a new cable (got one ordered). It appears as if the leak is not from the outer o-ring on the drive gear, but from the inside. Is this the correct seal to get:
Hi Alpamer, not sure if that is the correct one, you would have to match the number based on what the parts manual says. People here will confirm it for you. But for the price why not consider this from Z1Enterprises - Click Here. Once again, please confirm that this is the correct one for your model. You can always call them and give them your VIN and they will confirm.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- Thank you received: 2829
Attachment 00000_2013-01-22.jpg not found
- alparmer
- Thank you received: 2098
Click > www.kzrider.com/forum/2-engine/558813-in...in-tach-drive#558813
The old seal may be encrusted into the tach drive housing.
It's important to get all of the old seal removed.
May entail picking it out bit by bit, with the help of a good light and magnification.
A dental pic or similar tool may be helpful.
- alparmer
Stock '78 KZ650 SR
Attachment tachseal.jpg not found
- trianglelaguna
- Thank you received: 235
hay guys is there any way to order just the outer cheap (like 5 bucks ) seal and use some viton or decent orings inside,and not have to buy the metal drive housing...all the seal "kits" show the metal bolted piece and are 30-40 bucks?...does the metal part wear out too...am i being cheap here...mine leaks on everywhere...makes it look like my head is leaking...gets on the pipe...time to fix
www.z1enterprises.com/ItemDetails.aspx?i...Guide&item=PM81-2230
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- alparmer
I got everything installed and when I went to put in the new tach cable...freaggin' heck, the nut cracked again. Last time it cracked when I went to loosen it, now when I was tightening it. I didn't realized they were so fragile. I was tightening it with pliers, and it looks like it should only be by hand. The new cable I ordered was NOS. Now I have two perfectly good tach cables without the nuts that tighten them to the drive gear. What a waste.
Stock '78 KZ650 SR
- trianglelaguna
hand tight and snug with small pliers?
did you buy the whole "kit" like my link?
1976 KZ900
2003 ZX12R
2007 FZ1000
- alparmer
Stock '78 KZ650 SR
- alparmer
Stock '78 KZ650 SR
