- Thank you received: 337
Opinions On Stupid Tach Cable Oil Leak
- bountyhunter
Not sure what the story is on the cable, seems like it has leaked the majority of the time I owned the bike. It used to always crack and leak where the rubber cable meets the metal cable "inner". To fix that, I use a "split" hose splint wrap around with hose clamps in that area and that prevents that leak.
But I can't figure out how to fix the leak at the cinch nut.
FYI: if I hold the cable just ahead of the cinch nut, it does wiggle up and down a little which obviously means it is not being held firmly. The nut is tight, it just doesn't hold the cable lip well.
Is the internal O ring seal on the tach drive shaft supposed to seal well enough that oil can't get out to the cable?
- Thank you received: 2829
Attachment 00000_2013-01-18.jpg not found
- bountyhunter
Have to pull the camshaft?
- lushbaugh
- everybodys a pro......
- Thank you received: 35
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- Motor Head
- Thank you received: 391
- bountyhunter
I remember at the rebuild, the guide seemed to be frozen into the head. I thought it was some kind of a press fit item.
- mick z1a
- Thank you received: 11
- Motor Head
Motor Head wrote: In the Parts Fiche I don't see the usual screw and metal tab that secures it. But it shows the O-ring around the guide. It must come out like the others, but the part says its for the 750 twin Only. So it may have a different way to retain it. If you get the Guide to start coming out, use a magnet at the end of the pinion to hold onto it while removing the Guide, or a small pair of Needle Nose. That way the Pinion won't fall into the top of the motor, making the valve cover removal next on your list. Of course maybe its time to check the valves anyway, and removing the valve cover would ease the removal of the guide and pinion.
Good point - I don't see the screw or tab either. If it doesn't have the screw at least that won't be stuck and hard to remove like mine was. When I did my KZ650 I did remove the valve cover so I could get to the pinion, but I don't know if that is absolutely necessary. Ed
- ramtough_63
650ed wrote: That tach seal leak is a common problem; oil should not be seeping into the cable. The good news is it can be easily and cheaply fixed (guess how I know). I would replace parts 6, 7, and 9 in the diagram below (that's how I fixed my leak). All 3 parts are still available from Kawasaki and the total for all 3 is less than $9 at Ronayers.com so even the local dealer shouldn't charge much more than that. Check to make sure your specific model uses the same parts, but I'm pretty sure you will find that it does. Ed
I put an extra o ring in the cable in didnt help til i put a new number 9 in
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
- Motor Head
