Back Fire and popping at low Rpm
- Steve1986
12 Jan 2013 00:27
Hello every one.
i am hoping to find a solution to my problem. what i have is. A 1982 kz1000J bike has 6700 miles on it an has been sitting for a long time when i got it but ran when parked. My problem is at 4000 rpm or less it back fires (extremely load) and pops and caries on. 4000 rpm and higher it runs perfect rev's right up no pop no back fire will hold any rpm you wish above 4000. Things that have been done to fix this. New- plugs,plug wire, new pod filter, new mixture screws and o-rings, carbs have been cleaned multiple times,There spotless, i only changed the main jet up one size, carbs have been set and check multiple times, carb boots are not leaking they have been checked, and valves are in spec. if any one has any idea that would be great im running out
1982 kz1000J
Miles-6700
Miles-6700
- Lorcan
- Speed Loony
Re: Back Fire and popping at low Rpm
12 Jan 2013 05:21
Cam timing out a tooth?
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- Steve1986
12 Jan 2013 10:11
i dont think it is the cam timing because it was never messed with and it did run good at one point it started doing this when the carbs were hooked up being synced How would i check if its the timing advancer and could this be my problem ? the bike was close to being done ran pretty decent to the point were i rode it for a couple short distance rides figured sync the carbs and i was done
1982 kz1000J
Miles-6700
Miles-6700
- Old Man Rock
12 Jan 2013 10:19
Timing light...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
The following user(s) said Thank You: Steve1986
- Steve1986
12 Jan 2013 10:25
could the advancer be my problem or should i be looking elsewhere
1982 kz1000J
Miles-6700
Miles-6700
- Old Man Rock
12 Jan 2013 10:46
Your model = no moving parts, all electrical so most likely not...
With timing light, you can confirm if your pick ups @ "F" & advanced marking are working to spec but.... since operating at higher rpm most likely not your problem.
You have BS34 carbs...?
Were pod air filters always on this bike or did you just add them recently...?
BS 34's & pods, others have had issues dialing them in, stick with stock air box...
You mentioned jet size change, reasoning (new cams, 4-1 exhaust, head P&P etc...)?
Put the old jets back in and see if problem still there...
If all electrical/ignition timing/valve clearances etc... good, I'm thinking your carbies/jetting are the issue.
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Steve1986
12 Jan 2013 10:58
those are the carb i have. there were pod filters on this bike when i got it (air box wasn't there) i replaced with new k@n pods i went up on main jet only because of pod filter kept being told i had to because of the pods i am confident its not the electrical as it was gone over a lot this a multi-meter
i will be putting stock jets back in today
1982 kz1000J
Miles-6700
Miles-6700
- Steve1986
19 Jan 2013 17:59
So the problem was solved by putting the plugs back that cover the pilot jet and starting over again with the set and sync, And i did leave the bigger main jet in. Bike i ready for riding
1982 kz1000J
Miles-6700
Miles-6700
- bountyhunter
19 Jan 2013 21:34 - 19 Jan 2013 21:35Popping means lean. The old rubber intakes are notorious for leaking air. might want to check them.Steve1986 wrote: i dont think it is the cam timing because it was never messed with and it did run good at one point it started doing this when the carbs were hooked up being synced How would i check if its the timing advancer and could this be my problem ? the bike was close to being done ran pretty decent to the point were i rode it for a couple short distance rides figured sync the carbs and i was done
Last edit: 19 Jan 2013 21:35 by bountyhunter.
- Steve1986
19 Jan 2013 22:18
i thought popping meant lean as well but all i did was add the plugs back in i mentioned and during setting of carbs i set for more air with mixture screw and it stopped popping runs and starts like it should know but during my problem hunting i did check the rubber intakes they were fine.
1982 kz1000J
Miles-6700
Miles-6700
- chonus
20 Jan 2013 20:35
Does it still have the vacuum switch valve (the thing that sits above the cam cover) I've heard removal or incorrect operation can cause a backfire condition
-Dave
'82 kz305 lil bob
'82 kz1000 streetfighter project
'80 kz750/4 LTD
'02 kx125
'82 kz305 lil bob
'80 kz750/4 LTD
'02 kx125
- donthaveakawman
20 Jan 2013 20:46 - 20 Jan 2013 20:47Steve1986 wrote: could the advancer be my problem or should i be looking elsewhere
I just oiled mine, I took the non adjustable plate off there and went to town with my 3 in 1 oil.
Last edit: 20 Jan 2013 20:47 by donthaveakawman.
