Back Fire and popping at low Rpm
- Steve1986
i am hoping to find a solution to my problem. what i have is. A 1982 kz1000J bike has 6700 miles on it an has been sitting for a long time when i got it but ran when parked. My problem is at 4000 rpm or less it back fires (extremely load) and pops and caries on. 4000 rpm and higher it runs perfect rev's right up no pop no back fire will hold any rpm you wish above 4000. Things that have been done to fix this. New- plugs,plug wire, new pod filter, new mixture screws and o-rings, carbs have been cleaned multiple times,There spotless, i only changed the main jet up one size, carbs have been set and check multiple times, carb boots are not leaking they have been checked, and valves are in spec. if any one has any idea that would be great im running out
1982 kz1000J
Miles-6700
- Lorcan
- Speed Loony
- Thank you received: 59
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- Steve1986
1982 kz1000J
Miles-6700
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Steve1986
1982 kz1000J
Miles-6700
- Old Man Rock
With timing light, you can confirm if your pick ups @ "F" & advanced marking are working to spec but.... since operating at higher rpm most likely not your problem.
You have BS34 carbs...?
Were pod air filters always on this bike or did you just add them recently...?
BS 34's & pods, others have had issues dialing them in, stick with stock air box...
You mentioned jet size change, reasoning (new cams, 4-1 exhaust, head P&P etc...)?
Put the old jets back in and see if problem still there...
If all electrical/ignition timing/valve clearances etc... good, I'm thinking your carbies/jetting are the issue.
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Steve1986
i will be putting stock jets back in today
1982 kz1000J
Miles-6700
- Steve1986
1982 kz1000J
Miles-6700
- bountyhunter
- Thank you received: 337
Popping means lean. The old rubber intakes are notorious for leaking air. might want to check them.Steve1986 wrote: i dont think it is the cam timing because it was never messed with and it did run good at one point it started doing this when the carbs were hooked up being synced How would i check if its the timing advancer and could this be my problem ? the bike was close to being done ran pretty decent to the point were i rode it for a couple short distance rides figured sync the carbs and i was done
- Steve1986
1982 kz1000J
Miles-6700
- chonus
- Thank you received: 8
-Dave
'82 kz305 lil bob
'82 kz1000 streetfighter project
'80 kz750/4 LTD
'02 kx125
- donthaveakawman
- Visitor
Steve1986 wrote: could the advancer be my problem or should i be looking elsewhere
I just oiled mine, I took the non adjustable plate off there and went to town with my 3 in 1 oil.
