- Thank you received: 1
Stubborn starter clutch
- Spitfire151
Sadness.
I have it on it's side stand...I don't have enough room to use my jack and I'd have to remove the exhaust and really don't have room to have all the lying around.
Any thoughts?
- Motor Head
- Thank you received: 391
There are several posts on removal of the Rotor. They can be on there really tight. Be careful Hitting with a hammer, as the Magnets on the inside of the Rotor can come undone.
- Spitfire151
- Thank you received: 2098
Nothing should spin during attempt to remove the rotor by tapping on end of puller that's been tightened into the rotor.Spitfire151 wrote: ...just kept spinning... Still kept spinning....
What's spinning?
Perhaps the puller hasn't been sufficiently tightened into the rotor (before hitting the end of the puller with a hammer).
www.kzrider.com/forum/2-engine/399151-kz-porn
- mwriders
- if I only had a brain
- Thank you received: 6
By the way, if you happen to spin that thing even a little bit in the wrong direction, you are almost certain to slip the cam chain out of place.
1980 Kawasaki KZ440B (brand new eBaby)
1998 Ducati 900S (gone)
1978 BMW R100S (gone, damn it)
1975 Yamaha RD350 cafe (gone)
1986 Yamaha XJ650 Seca (gone)
1981 Kawasaki KZ440LTD (gone)
1969 HD Sportster (gone
1966 Honda CB160 (gone, damn it)
1965 Suzuki 80
- Spitfire151
- mwriders
Spitfire151 wrote: Crap and then what?
IF that happens, you reset the cam timing. It's not as complicated as it sounds, but does involve removing the cam cover, releasing the cam chain tensioner, probably removing the timing gear on the cam and then putting it back together. If you don't have the shop manual for your bike, you should probably acquire one. You can download one for free on the KZ400.com site.
1965 Suzuki 80
- Spitfire151
Thank you all so much for your help. I will let you know what happens next
- Spitfire151
Going to tear apart the carbs for good measure (never did it before but I know they need it).
- Motor Head
It could be the starter jet is partially plugged. Opening your idle Mixture screws another 1/4 turn might do it also. This is for Mixture Screws, which are at the engine side of the carb slide valve or throttle valve, which you should have, not the Air Screw at the Inlet side, VM carbs. Those you would turn In. Summer Idle adjustment may be to lean for the colder winter weather.
- Spitfire151
After opening the carbs I only found the head of one of the plastic plugs to be damaged (I think the PO did it ages ago). They were exceptionally clean and only one diaphragm had slight damage at its outer edge. Also I could not get the needles out, the screws were on so tight that I broke a screwdriver head. This gave me some time to clean the tank and prep it for repainting (it was the right color but done poorly and has gas stains). The petcock also had spray black on it and I cleaned it with a brillo pad and some fine grit sand paper, it gave the knob a really rustic look by leaving just aged black on it here and there lol and now I can read the fuel settings while on the bike without leaning way down and getting the light just right.
The in-petcock fuel filter I'm assuming is fixed in place? It is clean, just wondered. Checking my gas lines for cracks, there's really only a few at the tips but I will replace anyway, should I go with steel braided lines and in-line filters for each carb?
Lastly, this circles back to my starter clutch and I'm now fearing I didn't wrench it on tight enough or I did too tight. I used a torque wrench set properly so I'm quite confused. I will get the carbs and repainted tank back on and start over.
- Spitfire151
