- Thank you received: 299
While smoke/oil out of exhaust
- wireman
- BIGKEVIN
- Thank you received: 1
1976 KZ900
2006 ZX6R
- donthaveakawman
- Visitor
- BIGKEVIN
1976 KZ900
2006 ZX6R
- Thank you received: 2098
If tightened too much, the jet block will be pulled slightly out of perfect center alignment, whereby the throttle slide will bind as the throttle slide attempts to move up and down over the jet block.
- Motor Head
- Thank you received: 391
BIGKEVIN wrote: I had the #3 carb completely apart with no jet block in it and the throttle valve still does not go all the way down like the other 3 do when the throttle is closed. I goes down most of the way and then it stops, like it is binding on something. It is a new throttle valve and the old one does the same thing since I replaced the jet block.
Big Kevin said he has tried With Out the Jet Block installed, both the New and Old slide bind.
- BIGKEVIN
1976 KZ900
2006 ZX6R
- Motor Head
- donthaveakawman
- Visitor
Patton wrote: Screw 13 goes into bottom of the jet block to orient position of the jet block inside the carb.
so that's what those look like, I had no idea, is there a way to syncronise them?
- donthaveakawman
- Visitor
so that's what those look like, I had no idea, is there a way to synchronize them?
- BIGKEVIN
1976 KZ900
2006 ZX6R
