- Thank you received: 1
While smoke/oil out of exhaust
- BIGKEVIN
1976 KZ900
2006 ZX6R
- Motor Head
- Thank you received: 391
Just found them on their site with a deeper search, didn't come up under the 29 carb parts search.
www.z1enterprises.com/ItemDetails.aspx?i...ck&item=ZSMVM29%2f10
Or check with member testarossa in his thread he fixed his.
kzrider.com/forum/11-projects/340793-tes...?limit=20&start=1600 .
- Motor Head
- BIGKEVIN
1976 KZ900
2006 ZX6R
- donthaveakawman
- Visitor
don't use this stuff.
- BIGKEVIN
1976 KZ900
2006 ZX6R
- Old Man Rock
- Thank you received: 225
View #3 sparkie.... Oil fouled...?
If so, oil coming into combustion chamber thus White Smoke....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Motor Head
BIGKEVIN wrote: Is it possible that the bore somehow got out of round while I was taking the jet out ? How can I fix this ?
Where the Jet Block is held in, and its gasket. You may have to loose it, and re-adjust it a small fraction. Testing the slide valve fit. Repeat a few times until the slide fits correctly. This is a close tolerance where the 1et Block and Slide fit, getting it to fit without binding may take a couple of tries.
- BIGKEVIN
1976 KZ900
2006 ZX6R
- Motor Head
- BIGKEVIN
1976 KZ900
2006 ZX6R
- BIGKEVIN
1976 KZ900
2006 ZX6R
