can I fit '79 kz1000 headers to an '82 model?
- cas.vanderwoude
02 Jan 2013 23:56 #565644
by cas.vanderwoude
Motorcycles are like underpants - you should have one for each day of the week
can I fit '79 kz1000 headers to an '82 model? was created by cas.vanderwoude
hi folks,
I'm selling a Vance & Hines set of headers fitted to a '79 to someone who has an '82 kz1000. Will they fit or are there differences in the exhaust port measurements?
thanks in advance for all your help!
- zukdave
- Thank you received: 229
03 Jan 2013 00:45 #565651
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Replied by zukdave on topic can I fit '79 kz1000 headers to an '82 model?
It'll bolt to the motor. The rear mount may need work.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- MFolks
- Thank you received: 540
03 Jan 2013 02:15 #565663
by MFolks
Replied by MFolks on topic can I fit '79 kz1000 headers to an '82 model?
The early Kz1000's had 6mm studs for the exhaust clamps, but the later bikes had 8mm ones, so you'll need to enlarge the holes with a drill bit or reamer.
- wireman
- Thank you received: 299
03 Jan 2013 02:18 #565664
by wireman
Replied by wireman on topic can I fit '79 kz1000 headers to an '82 model?
that was the z1 exhaust flangesMFolks wrote: The early Kz1000's had 6mm studs for the exhaust clamps, but the later bikes had 8mm ones, so you'll need to enlarge the holes with a drill bit or reamer.
