- Thank you received: 7
Dual Plug cylinder head for GPZ 750
- RTGPZ
old school w/ new look
02gsxr 1000 front forks w/6 piston calipers
06 gxsr 750 rear suspension
6 speed trans out of gpz550
Reinforced frame
- justinz830
- Thank you received: 1
1979 KZ650 B3
1979 KZ1000 ST E1
- RTGPZ
Reinforced frame
- guitargeek
- Thank you received: 50
Please do!RTGPZ wrote: I won't bore you with details
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- wireman
- Thank you received: 299
6v coils?RTGPZ wrote: I seen Rob Muzzy use a dual plug cylinder head he built for 1983 AMA GPZ 750 Wayne Rainey s rode, and I had a spare cylinder head for an 83 gpz 750. So I went for it and thought I would post a thread with pic. I used an old magazine article for ref. I won't bore you with details about doing the milling and michining. I'm pretty excited to try it out next spring ,but I want to Dyno my bike with the stock head first to get some HP numbers then switch out to dual plug head and get HP numbers.I'm using Dyna 2000 ignition and four 6volt 1.5 ohm dual output ciols from dyna .Dynatec was very helpful when asking about conversion. :woohoo:
- RTGPZ
Reinforced frame
- RTGPZ
Reinforced frame
- wireman
- RTGPZ
Reinforced frame
- les holt
- Thank you received: 288
Les
- donthaveakawman
- Visitor
- Motor Head
- Thank you received: 391
Whats the rated secondary output on the 6V coils? Over 35KV? If not a set of 12v coils, 1 per plug or dual fire may very well have more spark energy.
