Dual Plug cylinder head for GPZ 750
- DoubleDub
Re: Dual Plug cylinder head for GPZ 750
23 Dec 2012 23:51
Not for a 750, but I know zed1015 has done it on his kz1000 head. I don't think it's any different than the 750 head for a dual plug setup.
Do you have a link to the coils you used? I'm interested in what the model is.
Not sure that dual plugging by itself will give you much extra HP, but I believe that when used in combination with higher cylinder pressures and higher octane fuel it can make a big difference in the amount of advance you can run.
- DoubleDub
24 Dec 2012 02:32 - 24 Dec 2012 12:03
(edited as the offending posts have been removed)
Last edit: 24 Dec 2012 12:03 by DoubleDub.
- zed1015
24 Dec 2012 06:53DoubleDub wrote: Not for a 750, but I know zed1015 has done it on his kz1000 head. I don't think it's any different than the 750 head for a dual plug setup.
I've done quite a few now.
Made up a drilling jig that bolts to the heads outer location dowels to get the plug positions exact every time.
I don't bother re-angling the four original plugs though as there's no measurable advantage but a nice touch,same as the the S1.
I use dyna-S and four dyna 1.5 ohm coils wired in series.
An easy set-up with just a short link wire needed and they work like a four post 3 ohm coil.
Set timing anywhere between 28 to 35 deg depending on spec etc.
- Lorcan
- Speed Loony
24 Dec 2012 19:07
There is a similar conversion going on here
www.750turbo.com/forum/viewtopic.php?f=8&t=10163
The Rainey bike had 4 coils and FWIW I think this is going to be down to which ignition is used more than the number of plugs.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- lushbaugh
- everybodys a pro......
24 Dec 2012 19:17les holt wrote: Can't say I've ever seen a dual plug head on a 750. Bet you have to pull a little timing out it to be where you want. Look on KZZone's website for greg copes tuning tips, I believe he talks about it.
Les
www.aperaceparts.com/cope.html
i keep it book marked lol cool stuff, says dual plug can allow 4 to 6 degrees less than single.
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- les holt
24 Dec 2012 20:37
There ya go, I knew I had seen it and didn't want to take any credit!
Les
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- dbsuperbiker
24 Dec 2012 20:39
my 70mm bore Z1 has dual plug head, and 6 degrees less spark advance is what works best.
- RTGPZ
27 Dec 2012 13:11
WOW!!
old school w/ new look
02gsxr 1000 front forks w/6 piston calipers
06 gxsr 750 rear suspension
6 speed trans out of gpz550
Reinforced frame
Reinforced frame
- zukdave
27 Dec 2012 18:16DoubleDub wrote: (edited as the offending posts have been removed)
No they ain't haveakaw's still here.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- Hollywoodmx
28 Dec 2012 14:10
Elevation will play a role in determining the optimum timing as well. Something to keep in mind for when others post their timing settings.
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
The following user(s) said Thank You: guitargeek, wireman
- wireman
28 Dec 2012 21:10That's same when it comes to any kind of tuning or performance numbers posted :laugh:Hollywoodmx wrote: Elevation will play a role in determining the optimum timing as well. Something to keep in mind for when others post their timing settings.
