- Thank you received: 36
1980 LTD transmission
- mtbspeedfreak
2000 ZRX 1100
1976 KZ 900- Daily Driver
- racer54
- Thank you received: 114
- Powerstroke_fan
- Thank you received: 83
racer54 wrote: The 1980 LTS trans is the same as a MK11 which is supposed to have a bigger second gear set. Same as a regular KZ1000 trans except the second gear set is supposed to be .030 wider. Know of some super.comp bikes running in the 8's using this trans. so should be strong enough for any street bike. Second gear was always the weak point in a KZ trans and this was done to fix that problem. Was told you can tell by looking for a "ring" around second gear but not sure about that part. I was always told a MK11 or one of these trans was the best KZ trans. Next step up would be a J model trans. and then the 83-84 GPZ trans which both require some mods to use in a KZ case.
Thats correct you can see the "step" on the top of the gear. Unlike the other which are just a flat gear.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- mtbspeedfreak
2000 ZRX 1100
