- Thank you received: 512
83 KZ750 won't roll in neutral
- baldy110
donthaveakawman wrote: is it ok to use brake cleaner to clean the chain?
If you want to re-use the chain and if it is an O-ring chain then no, do not use brake cleaner it will melt the rubber o-rings
- Thank you received: 2829
- Thank you received: 1656
That's how I do it, spraying the chain until it's dripping wet then wipe off the excess.650ed wrote: Use chain lube to clean the chain. Soak it real good with the lube then wipe off excess. Ed
LiquidWrench chain lube is cheap, so the method doesn't waste pricy lubricant. hee.
Sometimes I use a clean cloth dampened in mineral spirits.
- gengomerpyle
- Thank you received: 17
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
- donthaveakawman
- Visitor
Attachment newmuffla_2012-12-20.jpg not found
- ShayH
Thank you everyone for the suggestions, I know if I ever really need help this is the place to look
- LarryC
ShayH wrote: So I finally got to San Diego and got my bike here. I almost didn't want to come back here and post because I feel stupid. It turns out that the air was just real low in the tires, rolls great now! Hahaha.
:laugh: :laugh: :laugh: :laugh: :laugh: :laugh:
Larry C.
- Marklorenzo
1984 KZ700 A1
Ain't that the truth. My bike started weaving from side to side one time, so I guided the thing off the freeway as best as I could... the rear tire had gone flat. That was something.Marklorenzo wrote: Its crazy how much a low tire can do to a motorcycle. ...
- donthaveakawman
- Visitor
martin_csr wrote:
Ain't that the truth. My bike started weaving from side to side one time, so I guided the thing off the freeway as best as I could... the rear tire had gone flat. That was something. :ohmy:Marklorenzo wrote: Its crazy how much a low tire can do to a motorcycle. I am a little overexcited that before every ride I check the tire pressure. Glad to see everything worked out!!!
Beware the tankslapper, I have yet to have an at speed accident, but speed-wobble is best for bicyclists and skateboarders than a 60 mph motorcycle.
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
