- Thank you received: 13
Timing chain info for 79 MK2
- Roadflyer
Your opinions please.
1979 kz1000 shaftie rebuild project
1045 wiseco 10.25-1 pistons
Kenny Harmon 380 lift cams
- 4TheKZ1000
- Visitor
Attachment 0092640x533.jpg not found
arent those plastic? They are factory 32 tooth right.... Im sure they are plastic....if so mine are marked also....not to worry...
- Roadflyer
Thank you.
- Thank you received: 797
you just have to know they are plastic !!!!!!!!!!!!!!
and,
that you will be just fine .
- Roadflyer
Attachment 001_2012-12-05.JPG not found
531blackbanshee wrote: you don't have to know why :whistle: ,
and,
Well, That's a load off my mind! I saw those marks and thought I was in for new sprockets and timing chain. I just got the bike back together after a frame off restoration and noticed the marks when I put my Harmon Cams in this last weekend.
Thanks Guy's!
Don
- Thank you received: 2829
- 4TheKZ1000
- Visitor
- donthaveakawman
- Visitor
and,
Wal, Thet's a load off mah mind! Fry mah hide! ah sar them marks an' thunk ah was in fo' noo sprockets an' timin' chain, as enny fool kin plainly see. ah jest got th' bike back togither af'er a frame off resto'ashun an' noticed th' marks when ah put mah Harmon Cams in this hyar last weekend, cuss it all t' tarnation.
Thanks Guy's!
Don
ah occashunally is hard of hearin', so ah sometimes need t'use a translator fo' mah misspellin'.
- donthaveakawman
- Visitor
there is a plastic coating, I had the same problem on my falcon sports coupe.4TheKZ1000 wrote:
- donthaveakawman
- Visitor
really nice bike sir :evil: ,
