Width of collector / ODD KERKER FOUND??
  • 4TheKZ1000
  • 4TheKZ1000's Avatar Topic Author
29 Nov 2012 00:55 - 30 Nov 2012 15:23
#560416
I would love to ditch the sidewinder for a kerker.
where the 4 pipes go into the collector under the oil pan....could you please tell me what the greatest width of the pipe is.....in relation to ground clearance....
thanks
Last edit: 30 Nov 2012 15:23 by 4TheKZ1000.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: Width of collector on Kerker
29 Nov 2012 11:11
#560449
width or height?
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
29 Nov 2012 11:26 - 29 Nov 2012 11:34
#560453
i'm not sure i understand the question. but the Kerker has a 2 1/2" OD collector.
kzrider.com/forum/2-engine/271747-header-pics?limit=20&start=40
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 29 Nov 2012 11:34 by mark1122.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
29 Nov 2012 11:32 - 29 Nov 2012 11:39
#560455
If you are talking of clearance of the collector, the double-stacked exhaust pipes of a Kerker system won't fit under your motorcycle (as pictured in your avatar) w/out hitting the ground at every bump in the road. I haven't met a Kerker yet that didn't have dents just anterior to the collector with a normally sprung motorcycle...yours is considerably lowered.
To answer your question (I think), the double-stacked exhaust pipes at the collector are about 2 3/4" thick...the pipes are mounted within 1/4" of the bottom of the motor.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 29 Nov 2012 11:39 by Mcdroid.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
29 Nov 2012 11:35
#560457
Mcdroid wrote: If you are talking of clearance of the collector, the double-stacked exhaust pipes of a Kerker system won't fit under your motorcycle (as pictured in your avatar) w/out hitting the ground at every bump in the road. I haven't met a Kerker yet that didn't have dents just anterior to the collector with a normally sprung motorcycle...yours is considerably lowered.
X2 :(
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • 4TheKZ1000
29 Nov 2012 11:49
#560458
Yes...all thoughts to the bike and stance are correct. Thanks for OD of collector.
  • 531blackbanshee
  • Vendor
  • Vendor
29 Nov 2012 13:02 - 29 Nov 2012 13:04
#560469
marving has a 4 into one that has the collector with the head pipes side by side instead of stacked.
kinda like the four flat on this page.
www.coneeng.com/collectors.html
if you wanted to build it or have it built for you.
i think it would be cool to use the four flat collector then use a kerker meg and a custom mid-pipe to connect them,use some dual exhaust head pipes and voila :cheer: .
Last edit: 29 Nov 2012 13:04 by 531blackbanshee.
The following user(s) said Thank You: 4TheKZ1000
  • 4TheKZ1000
29 Nov 2012 18:39
#560513
Never seen a quick release kerker before....any ideas on this one....whats it worth?
Attachment 3Ic3F63M65Id5F75J8cb476e463005a0a1f4e432x207.jpg not found
  • 531blackbanshee
  • Vendor
  • Vendor
29 Nov 2012 18:43
#560515
hard to tell the condition from the pic.
what is it like dents/rust etc ?
  • 4TheKZ1000
29 Nov 2012 18:45 - 29 Nov 2012 18:47
#560517
531blackbanshee wrote: hard to tell the condition from the pic.
the guy said its good no dents...minor scrapes on collector....orig finish....minor rust..all parts there
Last edit: 29 Nov 2012 18:47 by 4TheKZ1000.
  • 4TheKZ1000
Re: Width of collector / ODD KERKER FOUND
29 Nov 2012 22:00 - 29 Nov 2012 22:04
#560553
Any ideas guys to what it is....if its rare and what its worth??
Attachment 3F43m93H55Kd5F25M3cb44144f10ef2221db7.jpg not found
Last edit: 29 Nov 2012 22:04 by 4TheKZ1000.
  • gengomerpyle
  • gengomerpyle's Avatar
29 Nov 2012 22:08
#560554
ive seen pictures of them before, maybe a racing pipe.
4TheKZ1000 wrote: Never seen a quick release kerker before....any ideas on this one....whats it worth?
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
