- Thank you received: 198
help ID cams
- peter1958
- Banned
- etbike3135
- Thank you received: 50
1973 Kawasaki Z1
18 years in dragbikes
- peter1958
- Banned
- 4TheKZ1000
- Visitor
kzrider.com/forum/2-engine/557751-how-to...-lift-at-home#559546
- peter1958
- Banned
- 4TheKZ1000
- Visitor
peter1958 wrote: 1.480 - 1.940=0.46
can you please explain these numbers..... :huh:
- peter1958
- Banned
- 4TheKZ1000
- Visitor
peter1958 wrote: Nose to heel is 1.480 Base is 1.090
390 lift...thats a hot street cam....
- LarryC
Larry C.
- 4TheKZ1000
- Visitor
LarryC wrote: Unusual to see a small base circle in a small cam like that
Larry, does BC have anything to do with duration?
Thanks
- LarryC
Thanks
At times, in some respects, yes but not drastically on those cams. It's lobe profile where it begins to change things as the base circle gets smaller. Two cams can have the same duration at a specific checking lift but be different in lobe profiles. As you reduce base circle significantly, the lobe shape can change.
On a virgin head, those cams are a candidate for 37.5 standard kz length intake valves because you have .020" smaller base circle. That translates into .010" or roughly 5 shim sizes. You gain half the measured reduce base circle in workable room to sink the valve for valve to valve clearance.
That is providing you run standard thickness buckets which in this case is no problem as they are a shim on top candidate without any issues.
Always look the nose over real good on a used cam. I have a lot of cams arrive with heads and the cams are worn out on one or more lobes. It's easy to spot by comparing the relative shape of the lobe points.
Larry C.
