How to check cam lift at home.
- 4TheKZ1000
10 Nov 2012 12:23 - 10 Nov 2012 14:18
How do I check my Camshaft Lift with tools I have at home?
I have seen several threads about this. Its not hard to do at home with tools on hand such as a vernier caliper and a pocket calculator.
OK....Measuring the lift of your camshaft. With a vernier caliper measure from heel of cam to peak of cam lobe. Move caliper keeping it snug to get the greatest number or the max lift. Now determine what your base circle of the cam is. Stock KZ is 1.110 base circle.
Take your max lift and subtract the base circle. This gives total valve lift. It’s that easy to determine a found cam or check for wear of your cams.
Spencer
Spencer
Last edit: 10 Nov 2012 14:18 by 4TheKZ1000.
- wireman
Re: How to check cam lift at home.
10 Nov 2012 12:44 - 10 Nov 2012 12:51
Couldnt you just use a dial indicator on the edge of a bucket?
www.amazon.com/dp/B002YPHT76/ref=bit_p_b...3_20120519_US_ie_ds_
It would be worth paying $25 for something like this just to have in the tool box to have for degreeing cams and other projects.
You could just make a small steel plate with a hole punched in it and bolt it to a valve cover bolt hole in the head and attach this to it.
Last edit: 10 Nov 2012 12:51 by wireman.
- 4TheKZ1000
10 Nov 2012 13:40 - 10 Nov 2012 13:42
This is also a great swap meet trick....if cams are unknown.....or just want to re check.
Last edit: 10 Nov 2012 13:42 by 4TheKZ1000.
- Powerstroke_fan
10 Nov 2012 13:52
Thanks for the info ill have to remember that
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
The following user(s) said Thank You: 4TheKZ1000
- T_Dub
10 Nov 2012 14:144TheKZ1000 wrote: The base circle? this is the cam journal where the cam caps and cam bearings mount. If you need to check base circle .... measure this part of cam. should be 1.110
The base circle is not the journal. The base circle is the round part of the "egg".
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- 4TheKZ1000
Last edit: 08 May 2013 00:27 by 4TheKZ1000.
- zukdave
22 Nov 2012 00:07
Spencer from T-Dub's pic. measure as it shows for base circle
that will give you the base number.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- 4TheKZ1000
22 Nov 2012 00:09zukdave wrote: Spencer from T-Dub's pic. measure as it shows for base circle
Im such a dumbazz...that snake bit me....
- 4TheKZ1000
Last edit: 08 May 2013 00:28 by 4TheKZ1000.
- 4TheKZ1000
26 Nov 2012 23:29 - 26 Nov 2012 23:44
Anyone running 1983 GPZ 1100 Cams in there bike.
Last edit: 26 Nov 2012 23:44 by 4TheKZ1000.
