- Thank you received: 14
Oil Cooling Engine.
- dejavoodo41
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- BohicaBob
- Thank you received: 35
One guy who is on kzrider.com put a Derale (I believe) 6" fan in the front of his KZ1000's engine and said this prevented any overheating. I know Derale now makes a 4" fan and I was toying with the idea of mounting it behind the cylinder head/block as one option.
- Powerstroke_fan
- Thank you received: 83
BohicaBob wrote: dejavoodo41: I know what you mean. During Bike Week in Daytona Beach, on A1A near Main St., with temps in the low 40's F, oil temp on my '73 Z1-900 was 215 degrees F in stop and go (mostly stop) traffic. A fan would tied into my oil cooler w/oil thermostat system would be ideal.
I think i purchase one of these and try them on my cooler with a adj thermostat. What would the ideal on temp for the thermostat be?
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- mark1122
- Keep twisting it
- Thank you received: 109
most thermosts come on at 180*. it will only run below 180 in cold weather, at that point the thermostat would stay closed and the motor will heat up to 180.i have 1 on my 1200. it still sees 235* with a 13 row Earls cooler. and that not stop and go trafic.
i dont see a reason for having it adjustable??
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Old Man Rock
- Thank you received: 225
OEM O-rings (from Z1), gasket, or something else....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
