Oil Cooling Engine.
- 4TheKZ1000
Oil Cooling Engine.
20 Nov 2012 15:48 - 20 Nov 2012 19:31
Ok...question to forum....
I want to and am going to install a oil cooler....
On cooling KZ 1000 engine.....I live in Ohio and its not uncommon to get 30 ..... 90+ degs days during the summer, tame compaired to some of the member climates on KZR.
What is a correct oil cooler size? I look at the lockhart and it looks very small. I think its a 3 or 4 runner cooler and feel its not providing the max cooling possible. I look at a Earl's 13+ cooler maybe at the limit or passing it. If Im going to put a cooler on my bike I want to max it out getting the max benifit.
Also....what is the max line size to be used. I would like to use AN6, AN8 OR AN10. I want to get oil to the cooler with proper pressure and be able to move oil around system.
Are there any mistakes people make? Any tech tips?
Thanks, Spencer
Thanks, Spencer
Last edit: 20 Nov 2012 19:31 by 4TheKZ1000.
- wireman
Re: Oil Cooling Engine.
20 Nov 2012 15:50
Try switching to synthetic oil first if you havent already and compare your oil temps
The following user(s) said Thank You: 4TheKZ1000
- 4TheKZ1000
20 Nov 2012 15:54
I went to Syn this month for first time....alot of stop and go in the city here....can take 30-mins to go 7 miles sometimes....dont get to do wide open ridding much....GRIDLOCK....
- MFolks
20 Nov 2012 16:36
Oil Coolers & Accessories
www.batinc.net/mocal-central.htm
www.holley.com/types/Temp-A-Cure%20Oil%20Coolers.asp
www.z1enterprises.com/Oil-Cooler-Fitting...0-KZ900-Z1-4520.aspx
Oil Temperature Gauges
www.motorcycleanchor.com/products/electro.html
www.tboltusa.com/store/daytona-oil-temp-gauge-150-p-1612.html
www.daytonamotorcycleparts.com/shop/shop.php...&shop_partPage=2
- Powerstroke_fan
20 Nov 2012 16:38 - 20 Nov 2012 16:38
You could always run a bypass. I believe i purchased an-6 line. I got a tru cool cooler i will see if i can get you the part number.
1977 KZ 1000 work in progress
Last edit: 20 Nov 2012 16:38 by Powerstroke_fan.
- StreetfighterKz
20 Nov 2012 16:55
When I was researching coolers for my 1428cc build, I e-mailed Earl's in the UK. The tech support is clueless in the USA. But the UK tech support deal with a lot of the streetfighters over there so they were actually able to answer my questions.
Just remember to say you have a '80 Z1000 engine or they might get confused if you use the Kz designation.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- Powerstroke_fan
20 Nov 2012 17:29 - 20 Nov 2012 17:31
I got a tru cool b7b it looks good havent installed it yet tho. But have prepped it up once a while back.
www.trucool.carshopinc.com/product_info....roducts_id/55218/B7B
Last edit: 20 Nov 2012 17:31 by Powerstroke_fan.
- 4TheKZ1000
20 Nov 2012 19:35Powerstroke_fan wrote: I got a tru cool b7b it looks good havent installed it yet tho. But have prepped it up once a while back.
I like the way this mounts over a Earl's cooler. Looks like a good cooler, will be looking at these also...thanks for the heads up.
- Powerstroke_fan
21 Nov 2012 17:29 - 21 Nov 2012 17:29
Let everyone know what you decide and i can show you the bracket and hardware i made to bolt it up if you want.
Last edit: 21 Nov 2012 17:29 by Powerstroke_fan.
- BohicaBob
- dejavoodo41
21 Nov 2012 23:48Powerstroke_fan wrote: I got a tru cool b7b it looks good havent installed it yet tho. But have prepped it up once a while back.
I've got that one on my bike and it made a major difference. I've also got a small fan that I haven't installed yet to help out with the stop and go traffic since it still tends to get hot being that it's an 1105. When I do my rebuild I think I'm going to drop down to a 1075 and make it more of a rider and less of a racer. Overall I'm very pleased with the performance of the cooler.
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- mark1122
- Keep twisting it
22 Nov 2012 00:27dejavoodo41 wrote:Powerstroke_fan wrote: I got a tru cool b7b it looks good havent installed it yet tho. But have prepped it up once a while back.
1075 to 1105. = not much dif.
i used the earls. it seems to be the most popular. the bigger the better. space is the only issue.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
