kz750 starter grind?
- andyvr4
1983 kz750 Ltd 4 cyl
1983 kz750 Ltd 4 cyl.
Andy
- Thank you received: 2829
- Thank you received: 2098
Hello, andyvr4, and WELCOME to KZrider forum!andyvr4 wrote: Ok thank you ahead of time for responses. Also I have been searching for my issue and thought it was my starter clutch but now I feel its not. Ok my starter sounds like its missing and grinding but no teeth wear, also clymers repair manual says if I can turn the gear toward the front of the bike it should spin freely, and when turning to the rear it should not turn at all by hand and by that test it is supposed to be good. So I'm stumped. Any thoughts?
VID_20121114_152514.3gp
Including information about bike year and model is helpful to viewers and usually elicits better responses.
It's easy to put the information in your signature where it shows in all posted messages, past and future.
And may be changed whenever and as often as desired.
If wanting a signature showing information about the bike in posted messages, it's easy to do. Here's how:
Attachment addsig.jpg not found
Attachment picpostnewsite912x671.jpg not found
- andyvr4
Andy
andyvr4 wrote: ...1983 kz750 Ltd 4 cyl.
Am thinking the 1983 KZ750 4 cylinder models with LTD styling include:
KZ750-H4 chain drive
KZ750-F1 shaft drive
KZ750-N2 shaft drive "Spectre"
This link includes a free down-loadable service manual.
Scroll down to and download "The Bible."
kz.bike-night.com/
Starters are likely the same for both chain and shaft drive KZ750 models.
- andyvr4
- baldy110
- Thank you received: 512
andyvr4 wrote: Chain driven
For future reference, since your bike is a 1983 KZ750 LTD with chain drive it can be identified as a KZ750-H4 when searching for parts, manuals, etc. Ed
- andyvr4
Andy
- Rowdymk2
- baldy110
andyvr4 wrote: Thanks for the search information. Is my starter clutch in the gear case? How could you tell your starter clutch was bad? Even the new one?
Because whenever I pressed the starter button the starter sounded like a can of rocks. It would turn the bike over but sounded terrible, that is the first symptoms of the starter clutch going bad. The next symptom is the starter slips while turning the engine over. Then it just stops working and spins without doing anything. With the new starter clutch that did not work I ended up replacing the rollers and springs in that one even though it came with new rollers and springs. That fixed the problem.
And yes your starter clutch is inside the case. You can replace it with the engine in the frame via the oil pan. I got pretty good at replacing it.
- andyvr4
Andy
