- Thank you received: 17
kz750 starter grind?
- gengomerpyle
29 Nov 2012 21:55 - 29 Nov 2012 21:56 #560552
by gengomerpyle
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
Replied by gengomerpyle on topic kz750 starter grind?
you can come do mine if you want
baldy110 wrote:
andyvr4 wrote: Thanks for the search information. Is my starter clutch in the gear case? How could you tell your starter clutch was bad? Even the new one?
Because whenever I pressed the starter button the starter sounded like a can of rocks. It would turn the bike over but sounded terrible, that is the first symptoms of the starter clutch going bad. The next symptom is the starter slips while turning the engine over. Then it just stops working and spins without doing anything. With the new starter clutch that did not work I ended up replacing the rollers and springs in that one even though it came with new rollers and springs. That fixed the problem.
And yes your starter clutch is inside the case. You can replace it with the engine in the frame via the oil pan. I got pretty good at replacing it.
1982 GPZ750R1 ELR
1971 Honda CB750K
Last edit: 29 Nov 2012 21:56 by gengomerpyle.
