- Thank you received: 58
kz1000 internals in z1 cases
- APE Jay
- Banned
20 Nov 2012 14:29 #559287
by APE Jay
Replied by APE Jay on topic kz1000 internals in z1 cases
OK, then here goes. I did the very first 70 mm pistons in the Z1 back in 73 or 74. Been doing it ever since with no problems.
We actually did some 70.75mm Z1s.back in the day.
In fact we have five Z1 blocks in the shop now all to be bored for 70 mm pistons.
- wireman
- Thank you received: 299
20 Nov 2012 15:25 - 20 Nov 2012 15:43 #559300
by wireman
Replied by wireman on topic kz1000 internals in z1 cases
Im gonna shut up and listen to Larry! :woohoo:
Im married ya know! :laugh:
Last edit: 20 Nov 2012 15:43 by wireman.
- Galactica
20 Nov 2012 21:43 #559362
by Galactica
77KZ1000
76 KZ900
Replied by Galactica on topic kz1000 internals in z1 cases
Thanks Larry, that's one more decision made.
Ross
Ross
77KZ1000
76 KZ900
- Galactica
27 Nov 2012 22:37 #560279
by Galactica
77KZ1000
76 KZ900
The head I will use for this build requires some work. I'll remove it and take it to a shop for repair of a cross threaded spark plug hole, valve grind, and guides.
However I would like your opinions. Should I consider having a few thou shaved off? I see no reason to believe that it is not flat, but while I have it off, why not?
Cheers,
Ross
Cheers,
Ross
77KZ1000
76 KZ900
- wireman
28 Nov 2012 00:59 #560298
by wireman
I dont know man,I myself am just a dumb married guy! :sick: :woohoo:
- Thank you received: 797
29 Nov 2012 12:04 #560462
by 531blackbanshee
Replied by 531blackbanshee on topic kz1000 internals in z1 cases
i would let a straight edge "make the whether to shave or not" decision for me.
you can always have it shaved,putting it back is a lil harder .
thats my .02 fwiw.
thats my .02 fwiw.
- Powerstroke_fan
- Thank you received: 83
29 Nov 2012 17:21 #560498
by Powerstroke_fan
Also how much can you shave off before you need to start worrying about the dowel pins being to long? Everyone needs to remember about the dowel pins. I remember someone talking about cracking there head bacause there dowels were to long.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic kz1000 internals in z1 cases
531blackbanshee wrote: i would let a straight edge "make the whether to shave or not" decision for me.
thats my .02 fwiw.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- Galactica
29 Nov 2012 22:46 #560563
by Galactica
77KZ1000
76 KZ900
Thanks, I'll set the machine shop decide. Best not to play around with it unless it's necessary. My aim is to have a reliable, flexible, no fuss motor. I prefer my current kz1000 motor over my kz900. It seems to be smoother overall and more torquey.
77KZ1000
76 KZ900
