kz1000 internals in z1 cases
18 Nov 2012 21:15 #559033 by Galactica
kz1000 internals in z1 cases was created by Galactica
Are there any issues with installing kz1000 internals in z1 cases? Essentially, I want to use the internals from a kz1000 engine that I have, with 900 jugs bored to accept the 1000 pistons, along with the 1000 head (the 900 head I have is cracked).
I will mate this Frankenstein motor with the 73 z1 carbs. I'm trying to build a sort of correct looking engine with parts that I have on hand. My gut says that mating the 1000 internals with the bigger z1 carbs should produce a really nice engine with smooth tractable power. I have yet to decide whether or not to put 6mm inserts into the 8mm exhaust stud holes. I'd like it to look, at a glance, like an original engine.
Any issues with the 1000 internals? Any issues with boring the 900 jugs that big? Any carb jetting issues? Any other thoughts?
Cheers,
Ross
77KZ1000
76 KZ900
18 Nov 2012 21:34 #559037 by MFolks
Replied by MFolks on topic kz1000 internals in z1 cases
Read this and then ask them:
www.aperaceparts.com/tech/techkz1000.html
  • z1kzonly
18 Nov 2012 23:42 #559058 by z1kzonly
Replied by z1kzonly on topic kz1000 internals in z1 cases
Nope! I have used an of upper case from 1973 mated to a bottom case of 1979.
Your Z1-KZ are so machined to precise standards that it works!
As long as you are the same crank pin size. And tranny size, no Mark II or GPZ tranny./
Just do it! then find out!
19 Nov 2012 01:09 #559076 by Galactica
Replied by Galactica on topic kz1000 internals in z1 cases
The 100 motor is a 78 kz1000 while the cases are 73 z1 900. From the APE article, it seems all should be good.,
Perhaps this next question should be put in the carb section. Assuming I go this route, and am basically mating the stock Z1 carbs with the 1000 engine, what jetting should I start with?
Cheers,
Ross
77KZ1000
76 KZ900
  • z1kzonly
19 Nov 2012 01:39 #559080 by z1kzonly
Carbs are your last worry!
If you get your engine together, that's all that counts.
900- 1000 don't matter, 26 mm carbs, 120 pilot's, 120 -125 mains, drop jet clip to bottom
and your running.
19 Nov 2012 05:34 - 19 Nov 2012 05:37 #559092 by Garn
Replied by Garn on topic kz1000 internals in z1 cases
Galactica, everything should be Ok, however, there are a few of items that could cause some concern.
1. the Z1 uses a 2 coil spring on it's gear-change mechanism, whereas, the Z1000 uses a 3 coil spring, which is obviously bulkier and will causes the inner sprocket cover on the Z1 cases, not to seal. The Z1000 accommodates the spring by having a recess in its bottom casing. So, its simply a matter of using the z1 spring.
2 The Z1 casing usually provide for the 1015 barrels, but it's worth checking. I do know some cases have to machined out to take the larger barrel liners.
3. When finishing the Z1000 barrels to give the same "fin linished finish" as the Z1, you will find these fins are thinner and also have small dimples along the fin. Makes it a bit hard!
I would go for Z1R Mikuni "High-top" carbs.
Oh! don't bother with changing the exhaust studs, 8mm look the part anyway!
RegardZ
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
Last edit: 19 Nov 2012 05:37 by Garn.
19 Nov 2012 10:18 #559101 by toad
Replied by toad on topic kz1000 internals in z1 cases
check top idler gear for valve cover fitment,z1 and kz1000 I believe are slightly different.ran into that problem before, depending on which valve cover you are going with.
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
  • wireman
19 Nov 2012 11:17 #559110 by wireman
Replied by wireman on topic kz1000 internals in z1 cases
Garn wrote: Galactica, everything should be Ok, however, there are a few of items that could cause some concern.
RegardZ
You could have the 900 cylinder bored and put the 1000 sleeves dropped into it if you really want to be sneaky B)
19 Nov 2012 22:54 #559217 by Galactica
With respect to boring the 900 barrels to accept the 1000 pistons, my understanding is that it can be done, but that it is the maximum size they can be bored.
Would there be any issues other than upper case clearance? The upper case can be machined to accommodate the bigger diameter of the barrels.
With the cylinder walls being that thin, are there any heat related issues?
Regarding the Z1 gear change double spring spring, I have a unit I can use.
I agree the carburration is the last thing to worry about. I just get ahead of myself sometimes.
77KZ1000
76 KZ900
  • wireman
20 Nov 2012 02:47 #559245 by wireman
I dont like seeing any sleeve being bored to its maximum size myself ,ive seen too many good engines turned into door stops in cars and bikes due lack of support in cylinder walls as motor heats up they turn to more of an egg than a round cylinder. :sick:
Now the pros will come on and tell me Im wrong! :woohoo:
  • bluej58
20 Nov 2012 08:40 #559263 by bluej58
Replied by bluej58 on topic kz1000 internals in z1 cases
I have a spare output shaft and gears off a 76 900 that I want to swap out for the output shaft and gears on my spare 77 1000 motor, should work right ?
JD
78 KZ1000 A2A
20 Nov 2012 08:57 #559266 by LarryC
Replied by LarryC on topic kz1000 internals in z1 cases
wireman wrote: I dont like seeing any sleeve being bored to its maximum size myself ,ive seen too many good engines turned into door stops in cars and bikes due lack of support in cylinder walls as motor heats up they turn to more of an egg than a round cylinder. :sick:
Attachment if-you-are-wrong-and-shut-up-you-are-wise-if-youre-right-and-shut-up-youre-married.jpg not found
:kiss:
Larry C.
