- Thank you received: 2098
Stock torque curve for 1997 KZ1000P?
23 Nov 2012 01:16 - 23 Nov 2012 01:17 #559704
by Patton
Next time into the carbs, would check the clip positions on the jet needles, and return all clips to the middle position;
and assure jet needles and needle jets are clean and in good condition;
and also try to assure that the jet needles are stock sizes (kawasaki.com may show the jet needle sizes), as the jet needles might have been replaced from some after-market kit.
Would also lube the pivot points on the timing advancer; and assure the advancer is functioning properly by watching it under a timing light to observe it quickly moving back and forth as rpm is varied by blipping the throttle.
And also perform the clear tube test on each carb to assure that fuel levels are within specs.
Replied by Patton on topic Stock torque curve for 1997 KZ1000P?
imon_2nd wrote: ...seem to have a flat spot between 4,000 and 5,000 RPM. Pulls hard on both sides of that range. Normal?....
Last edit: 23 Nov 2012 01:17 by Patton.
- imon_2nd
- Architect & Engineer
- Thank you received: 4
23 Nov 2012 18:59 #559786
by imon_2nd
Keepin' the rubber side down.
Replied by imon_2nd on topic Stock torque curve for 1997 KZ1000P?
Thanks again, Patton.
I've done most of that, except for the timing advance mechanism lube job. Will do. Didn't think to check jet or needle sizes. The motor appears to be box-stock.
I had no idea my favorite Castrol GTX was no longer good for bikes. Now, I'll have to change the oil in all three (Kawi, Suzi, and Honda).
Cheers,
Cheers,
- P21
- Thank you received: 34
24 Nov 2012 01:47 - 24 Nov 2012 01:48 #559831
by P21
Kawasaki KZ 1000 Police (2002) P21
Replied by P21 on topic Stock torque curve for 1997 KZ1000P?
mine runs sweet but then i did my own carbs and real carb syc.
i have been in alot of carbs in the days stuff is easily looked over like you did not check your jet numbers and such.
as to that poor maintance on advancer you over looked,in the end little shit will bite you in the azz.
sorry i am machinist by trade so i am anal........lol
hope it works out for you. dont mean to be so hard on you but i dont like doing things twice except gettin pussy.
Last edit: 24 Nov 2012 01:48 by P21.
- imon_2nd
24 Nov 2012 16:33 #559877
by imon_2nd
No offense taken, P21.
Nice to meet another KZP rider.
Cheers,
Cheers,
