WTF 78 KZ1000 kicker
- Ogcoda
- Killing Everything
1978 kz1000 Bobber
2006 MazdaSpeed6
- Thank you received: 2829
- MFolks
- Thank you received: 540
- Old Man Rock
- Thank you received: 225
Even with clutch plates/oil/sitcking to loose etc... this seems to me to be something different altogether...
Same time, loosen clutch adjustment and test, simple enough starting place.
Take off you kick start plate insuring spring arm/adjustment is correct, inserted into shaft hole, insetred into encase hole, not broken etc....
Had you / PO ever had this apart for the spring must be installed correctly (spring load orientation) to work correctly.
Off my KZ900 should be exactly as your '78 1000 for ideas but confirm in you manual exact configuration.
NOTE: Z1, KZ900 and up to 1980 KZ 1000 engines ~ 98% the same (other than displacements and some other minor details)....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- mark1122
- Keep twisting it
- Thank you received: 109
Ogcoda wrote: So about a month ago i pulled my bike out of the garage and kicked it over. took a few kicks as usual but started non the less. i take it out this week and go to kick it over and there was almost no resistance.... the kicker can be pushed all the way down with one finger but then springs right back. I had the points cover off to see if the nut was spinning as i kicked it and it would barley spin when kicking it. I checked compression and it pulled alot better numbers then i thought it would. 125 125 130 and 125 I'm kinda lost on what could be going on. Anyone have any ideas?
there seems to be some confusing info here.
if the kicker goes down with no resistance,(crank cant be turning) how can there be 125psi compression? cant see it happening?
if the kicker goes down and the crank bolt under the points cover barely turns how can u have 125 psi ?
i would follow OMRs lead on the kick. seems like its not engaging .
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Thank you received: 797
spring #11 would still return it but it would not engage.
- mark1122
- Keep twisting it
531blackbanshee wrote: i wonder if spring #3 is broken and not letting the cogs engage each other?
that was my first thought too. but then he said he checked the compression??? maybe he used the electric starter for that ??
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
i am pretty sure that would have been the only way he could have checked the compression,given his current situation.
