- Thank you received: 2098
Cant get cam timing right, going crazy
10 Nov 2012 02:10 - 10 Nov 2012 02:13 #557731
by Patton
When viewed under a timing light at higher rpm, the twin advance marks are supposed to align with the case mark.
Replied by Patton on topic Cant get cam timing right, going crazy
Last edit: 10 Nov 2012 02:13 by Patton.
10 Nov 2012 02:16 #557732
by Patton
These links are to info and suggestions contributed by RonKZ650:
www.kzrider.com/forum/2-engine/475461-re...ving-the-cams#475461
www.kzrider.com/forum/2-engine/249136-re...seating-issue#249136
www.kzrider.com/forum/2-engine/221680-revalve-clearance#221680
www.kzrider.com/forum/2-engine/146192-revalve-shims#146192
www.kzrider.com/forum/2-engine/21185-re6...lve-clearances#21185
- donthaveakawman
- Visitor
10 Nov 2012 03:24 #557733
by donthaveakawman
Replied by donthaveakawman on topic Cant get cam timing right, going crazy
I am not a big fan of having to time cams. although i am looking for one of those center spinamagig under the bolt and washer for the timing dealy. It has the two tangs on there and one of my tangs broke so i am not sure if i really need it, but i would like to replace it.Patton wrote:
- donthaveakawman
- Visitor
10 Nov 2012 03:28 #557734
by donthaveakawman
What kind of engine is this, i think you are in the wrong place. this is for KZ for going crazy.
10 Nov 2012 10:12 - 10 Nov 2012 10:24 #557743
by Patton
The F
mark is used in connection with ignition timing (when spark plugs fire).
The T mark is used in connection with cam timing (when valves open and close).
Last edit: 10 Nov 2012 10:24 by Patton.
- loudhvx
- Thank you received: 1616
10 Nov 2012 12:47 - 10 Nov 2012 12:52 #557754
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Cant get cam timing right, going crazy
Are you sure nothing fell into the cam chain tunnel? Are all of the valve cover half-moons accounted for?
The symptom of chain slack jumping, and marks being different after a rotation, are signs that something is on the timing chain's crankshaft sprocket.
Also, this kind of thing can happen if you turn the crank backwards. It should only go forward. On the inline-fours, the crank should rotate the same direction as the wheels.
1981 KZ550 D1 gpz.
Other links.
Last edit: 10 Nov 2012 12:52 by loudhvx.
- donthaveakawman
- Visitor
10 Nov 2012 20:33 #557809
by donthaveakawman
looks like the inlet side could be moved down two links
- RonKZ650
- Thank you received: 240
10 Nov 2012 22:05 #557816
by RonKZ650
Replied by RonKZ650 on topic Cant get cam timing right, going crazy
All you can do is after putting the engine at the T mark, line up your exhaust arrow to the top of the head. It may not be exact because of possible cam chain wear. All you can do is pick the chain link that is closest to being aligned correctly. After this count back your pins to the intake and install the cam. If the intake is then not aligned with the head, most likely the cam chain is stretched beyond normal service limits. This is what it sounds like to me. Of course the tensioner takes up slack, but the measured length of the chain between the cams and their timing marks can be longer by an entire 1T or more on a worn chain, so the intake will be more retarded in timing the more worn the chain gets.
- donthaveakawman
- Visitor
11 Nov 2012 00:49 #557826
by donthaveakawman
I wonder how many combinations there are. Kinda like a combination lock. so many to the right so many to the left and so many to the other way, how many teeth are on those cogs?
- gixxerfiend
14 Nov 2012 20:38 - 14 Nov 2012 20:38 #558373
by gixxerfiend
2006 GSXR 1000
2005 CBR 600rr
1977 KZ 650
Replied by gixxerfiend on topic Cant get cam timing right, going crazy
Ok so I put it back together how I had it in the picture and it runs good. I guess maybe with cam chain wear they dont line up exactly where the manual says like ronKZ650 suggested. There was nothing I could do to get them any closer. Man this was a nightmare of a job. all was going good untill I dropped one of the cam guide sprocket spacers down in the tunnel and it was downhill from there. It took me 2 hours to locate it not counting the time removing the header and oil pan. Next time I will stick a rag in it to be sure nothing falls down in there. Thanks again for all the help, had I not posted those pictures I would still be trying to line those damn things up per manual. I also ran a high mixture of seafoam before I synced the carbs and now this thing will wheelie quiet easily lol
2006 GSXR 1000
2005 CBR 600rr
1977 KZ 650
Last edit: 14 Nov 2012 20:38 by gixxerfiend.
- OldSchoolZ
- Thank you received: 33
14 Nov 2012 22:20 #558387
by OldSchoolZ
Remember, don't work on your bike so much you never ride it.
Replied by OldSchoolZ on topic Cant get cam timing right, going crazy
And remember, if you have the bike leaning while doing this, it is very easy to have the chain slip a tooth or more on the crank. I always have Z's straight up and down when doing cam timing. Ive seen it drive people nuts.
