Cold Exhaust
  • Surfdude_007
  • Surfdude_007's Avatar Topic Author
Re: Cold Exhaust
12 Nov 2012 14:48
#558060
Timing is perfect. Not it.
1980 KZ1000 B4 LTD
1982 KZ1000 LTD
Re: Cold Exhaust
12 Nov 2012 16:50
#558075
mark1122 wrote: ...a dual feed pingle will not help.
u need to figure out why u r not getting fuel to #3,and 4 carbs.
Would perform clear tube test on #3 and #4 carbs to determine fuel level in each carb.
And also assure that the floats aren't installed upside down.
Good Fortune! :)
  • donthaveakawman
  • donthaveakawman's Avatar
Re: Cold Exhaust
12 Nov 2012 17:23
#558076
It's a terrorist plot to piss you off. What i would do is make sure that you get fuel to 3 and 4 otherwise it's gonna be uneven, also make sure the timing is good, probably electric anyways. then we can see about one of the cams possibly coming off.
yeah probably just the fuel though.
  • Surfdude_007
Re: Cold Exhaust
12 Nov 2012 19:14
#558097
OK, here's the news. I pulled off the valve cover and went through every check in regards to timing this thing on this website. It checks out. Not a timing issue. I did check the DynaTek website and looked at which one I had installed. OK I think the guy put on a Suzuki ignition. The reason I say this is because I have red,black, and white wires. The website indicates that for a kawasaki large four it is supposed to be black, red, and green. Would this be a problem? Also the black and white wires were on the wrong coils. Could this be the culprit? I will buy some clear fuel line tomorrow and install.
1980 KZ1000 B4 LTD
1982 KZ1000 LTD
  • donthaveakawman
Re: Cold Exhaust
12 Nov 2012 21:12
#558119
that is a really good idea! :woohoo: . I was doing the same thing, but only wiping oil on the exhaust pipes to see what one burns off the quickest. wow, where can i find one of those?
  • donthaveakawman
Re: Cold Exhaust
12 Nov 2012 21:22
#558124
Surfdude_007 wrote: I will apologize beforehand as this is probably a newb question.
I have a 1980 KZ1000 LTD B4. It runs but I had a problem with a new battery. It would discharge and as soon as I hooked it up to the bike it wouldn't turn it over. I bought a gel battery at the local Advanced autoparts store. Hopefully It will be OK.
Now to the question. As the bike runs but it doesn't have the power and it has a kind of muffled sound when you give it the throttle. I took heat readings with an infrared temp gun. The left two exhausts were at 630 degrees and the right two were at about 117.0 degrees. Any ideas on this? Thanks!!
I want to buy one of those thermometers, but first I have to know, does it work on a barbecue?
  • Surfdude_007
Re: Cold Exhaust
12 Nov 2012 21:24
#558126
Home Depot, Lowe's, Sears,
1980 KZ1000 B4 LTD
1982 KZ1000 LTD
  • Surfdude_007
Re: Cold Exhaust
12 Nov 2012 21:25
#558127
-58F to 1000F
1980 KZ1000 B4 LTD
1982 KZ1000 LTD
  • Surfdude_007
Re: Cold Exhaust
13 Nov 2012 17:54 - 14 Nov 2012 01:27
#558224
@Patton,
I did find the splice. It was a two into one type of connector. It looked like it might have gotten a little warm in the past. I cleaned and sprayed deoxit on it and put it back together. I also had the wrong wires connected. still won't start. I'm baffled. The sad part is that I don't trust anyone here(key west) to work on anything with an engine. Inspecting the carbs tomorrow.
1980 KZ1000 B4 LTD
1982 KZ1000 LTD
Last edit: 14 Nov 2012 01:27 by Surfdude_007.
  • donthaveakawman
Re: Cold Exhaust
13 Nov 2012 19:06
#558240
It's your fuel map, it's got a nasty hole :blush:
  • Surfdude_007
Re: Bonehead of the Year Award!!!!
28 Nov 2012 18:38
#560361
Always remember to align the crank trigger correctly if you expect your motorcycle to run at all. I nominate myself to the aforementioned position. Thank you all who attempted to assist me previously.
1980 KZ1000 B4 LTD
1982 KZ1000 LTD
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
28 Nov 2012 18:48
#560362
Glad you found the problem.
