What cam to use (1075)?
  • LarryC
  • LarryC's Avatar
Re: What cam to use (1075)?
05 Nov 2012 00:27 - 05 Nov 2012 00:30
#557079
kzz1king wrote:
LarryC wrote: Bowl volume...think bowl volume if you'r going to have a go at the ports ;)
If anyone is having a go at my ports it will be you! What do you mean by bowl volume? carbs?
Wayne
Area around the guide.
My advice is to steer away from shim under type cams. Cost isn't worth the investment on the overall unless you're doing a very serious engine.
Larry C.
Last edit: 05 Nov 2012 00:30 by LarryC.
The following user(s) said Thank You: BlackZ1R, kzz1king
