What cam to use (1075)?
- kzz1king
30 Oct 2012 22:56
I have very mild cams right now. 360 I believe. Stock heads, 29's 1075 kit. Would I gain much by going with something a little more aggressive? What will I lose?
Thanks
Wayne
Thanks
Wayne
Home built KZ1000 turbo setup
- 4TheKZ1000
Re: What cam to use (1075)?
30 Oct 2012 22:59 - 31 Oct 2012 00:27
well this is opening up a can of worms....
I feel without increase air flow CFM...though the head....you are not going to realize the HP gains for the money....you need to port head if you go bigger. I think a KZ head flows 70 cfm while a J head with 32/38 would be around 103 cfm.....if you could get close to 90 on a KZ would be gr8....but would probley include a valve upgrade.... 30/37.5 or so cant rem kz valve...would include wicked port job....but 90 or over would be tits on CFM.
shim on top....I like Web Cams grind #110 395 lift.You can run this cam with mild port job. I have heard of people running 420 lift cams with shim on top but you are asking for possible problems....I wouldnt do it.
Shim under...I might look at Cam Motion grinds based on bench test cfm flow of head matched with cam and cams RPM range. I would reccomened a serious port job 420 lift and up. You have to get all components to work toghter not aginst eachother....this is where experiance of an engine builder comes into play.....not the guy at the kawasaki dealer.
Larry C. would be the guy to ask....I have read some of his stuff on this subject and its tightski....I would ask him.
Last edit: 31 Oct 2012 00:27 by 4TheKZ1000.
- kzz1king
30 Oct 2012 23:30
The infamous can of worms! I have toyed with the idea of having the head done. Just don'tknow how muchI want to put into it. All I do is go out and burn rubber like I am 16.
Wayne
Wayne
- 4TheKZ1000
30 Oct 2012 23:37kzz1king wrote: The infamous can of worms! I have toyed with the idea of having the head done. Just don'tknow how muchI want to put into it. All I do is go out and burn rubber like I am 16.
Wayne
well port job: $200 to $300
cam new: $400 to $500
Springs $$$$$
cams timed $$$$$
Gaskets $$$$$
items I forgot to list $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
It aint cheep brother..... :ohmy: :ohmy: :ohmy:
- wireman
30 Oct 2012 23:51
Try the cams you already have with a stage 1 port job from Larry,Id say that would be best bang for the buck
- kzz1king
31 Oct 2012 13:31
I already have APE springs in it and slotted cam sprockets. It took me a bit to degree the last set but I got it done.
The porting isnt bad but if I replace valves and guides the parts start adding up.
Wayne
Wayne
- wireman
31 Oct 2012 19:40
Well a stock head can only move so much air no matter what cams you have,thats why I say to have the head done which will give you a more streetable combination than big choppy cams
- kzz1king
31 Oct 2012 20:55wireman wrote: Well a stock head can only move so much air no matter what cams you have,thats why I say to have the head done which will give you a more streetable combination than big choppy cams
I agree Wireman. I listed the above to point out I would not need springs if I port the head and can do the install myself. The cost of head porting is not bad but not sure if I would need to replace guides and valves. That is what starts to get costly. From what I hear though the headwork really pulls it all together.
Wayne
- LarryC
31 Oct 2012 22:40
Bowl volume...think bowl volume if you'r going to have a go at the ports
Larry C.
- kzz1king
01 Nov 2012 13:24If anyone is having a go at my ports it will be you! What do you mean by bowl volume? carbs?LarryC wrote: Bowl volume...think bowl volume if you'r going to have a go at the ports
Wayne
- APE Jay
- wireman
02 Nov 2012 21:23Maybe after he has the head done,depending on how he plans to ride itAPE Jay wrote: K410s and VS900K springs.
