What is the correct compression ratio for a KZ 900
  • jerry chabino
  • jerry chabino's Avatar Topic Author
29 Oct 2012 19:30
#556264
Hello all,
I have conflicting info on the kz 900 compression ratio. My compression ratio is 112 -115 hot across all four cylinders. Is this OK ?
I have heard the Clymer manual says 130 and another manual says 115. Sure could use some help on this. Bike has 9500 miles is runs really bad. I would hate to spend $$$$ on a rebuild when not necessary.
Thanks,
Jerry
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
Re: What is the correct compression ratio for a KZ 900
29 Oct 2012 19:48
#556272
Jerry, I went and grabbed my Clymer since I relied on memory before. It says 130-160 psi. But remember, this is not a model/year specific manual. Covers Z & KZ900-1000cc chain & shaft 1973-1981 (Clymer M359-3). The other manual I got from here online and it the Kawasaki Shop Manual Z1 Series and seems to be from around 1972. It states 121 lb/sq in standard and 85 lb/sq in. service limit. Hope someone else with more information can chime in.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • taildragger1197
  • taildragger1197's Avatar
29 Oct 2012 20:10
#556274
Did you pull all 4 plugs out and crank with the throttle wide open and with the battery fully charged?
Union City, Tennessee
1979 KZ1000 LTD B3
1979 KZ1000(1260)LTD S/G Pro ET
1993 ZX11 D1 Ninja
  • jerry chabino
29 Oct 2012 21:12
#556283
sure did.
tnx taildragger
  • jerry chabino
29 Oct 2012 21:14
#556285
tnx Joe. When I added a teaspoon of oil to each cylinder compression jumped to the high 160 range
  • Nebr_Rex
  • Nebr_Rex's Avatar
29 Oct 2012 21:18
#556287
That is not a compression ratio,8 to 1,10 to 1 is.
jerry chabino wrote: Hello all,
Thanks,
Jerry
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Motor Head
  • Motor Head's Avatar
29 Oct 2012 22:15
#556296
I wouldn't be happy with those compression #'s. There is a big difference between dry and wet for one thing, but 115, you would need to be around 8K feet above sea level. The bike would run and should be smooth, but less power with those #'s. So you may well have other issues. Ignition and carburetion come to mind. Possible vacuum leaks etc.
  • wireman
  • wireman's Avatar
29 Oct 2012 23:56
#556313
jerry chabino wrote: tnx Joe. When I added a teaspoon of oil to each cylinder compression jumped to the high 160 range
Sounds like its time for rings atleast if the bores are still in spec,but If Im going to all the trouble to pull the top end off Id go ahead and have a real valve job done including new seals if the guides are still good.
Dont forget to check cam chain and related stuff and atleast drop the pan and check oil pump pick up screen B)
The following user(s) said Thank You: Tomolu5
  • APE Jay
  • APE Jay's Avatar
30 Oct 2012 00:59
#556323
The numbers you are talking about are cylinder pressure, not compression ratio.
Compression ratio is a mechanical number that won't change with engine wear, cam timing, oil in the plug hole. Cylinder pressure will.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
30 Oct 2012 09:56 - 30 Oct 2012 09:57
#556365
decent rule of thumb is,
for any internal combustion engine.
it takes 65lbs of compression to even create combustion.
a good number is the 140-160 lb range with a compression tester in five kicks with the throttle open.
if you are using oil to help your numbers you are grabbing at straws.
100 lbs of compression is time for a rebuild.
anything less is dieing a slow death.
this info is free,take it for what its worth,your mileage may very,caveat emptor.
Last edit: 30 Oct 2012 09:57 by 531blackbanshee.
  • baldy110
  • baldy110's Avatar
30 Oct 2012 12:28
#556379
I have had engines with low compression numbers that had been sitting for awhile. The rings get stuck and after getting it running then running it for a few hundred miles the compression numbers would come up to normal.
  • wireman
  • wireman's Avatar
30 Oct 2012 16:30
#556414
baldy110 wrote: I have had engines with low compression numbers that had been sitting for awhile. The rings get stuck and after getting it running then running it for a few hundred miles the compression numbers would come up to normal.
This can also be the case,just depends on the circumstances and how much time/patience you have. B)
