What is the correct compression ratio for a KZ 900
- les holt
Re: What is the correct compression ratio for a KZ 900
30 Oct 2012 18:08
before you get too far I'd check valve lash. Your going to have to take the valve cover off anyway for a freshen up so why not? At 9500 miles you may just be real tight on lash which will kill cylinder pressure. Just a thought.
Les
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- jerry chabino
03 Nov 2012 14:44
thanks for all the info guys. I will get to the bottom of this and post.
- jerry chabino
14 Nov 2012 19:26
Hi Guys,
Problem solved !!! The green wire from one of the point sets had a bare spot and was intermittently shorting out.
Thanks for everything
14 Nov 2012 22:51
nice easy fix! :woohoo:
- LarryC
