Z750L3/KZ750R starter clutch
  • Jesper
  • Jesper's Avatar Topic Author
27 Oct 2012 10:30
#555999
Need to repair the starter clutch on my Z750.
I know it can be done with the engine still in the frame.
Is there a "how to" guide somewhere?
I know I can gat to it from the bottom, and that the clutch basket has to come of. But what else
Regards
Jesper
  • Calico
  • Calico's Avatar
Re: Z750L3/KZ750R starter clutch
27 Oct 2012 12:35
#556009
I just had to do this job on my 82' 750ltd. Yes, if time is a factor, you can do this with the engine in. Though reassembly is like playing Jenga backwards. Gravity becomes your enemy and you'll find yourself wishing you were born with a small extra arm growing out of your neck. (you'll see what I mean). So, you'll be removing; both covers, clutch assembly, exhaust, oil pan, secondary shaft cover plate, starter, oil pump; just to give you an idea of what you are getting into. It may sound daunting at first but as long as you remain methodical and pay attention to detail, it's not that painful. Do you have the Clymer book? There are also some helpful threads here. But if you want, since I'm in bed with the flu (blech) I have time to walk you through this step by step if you need. Also, is your bike a kz, zx? And what year please?
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
  • Motor Head
  • Motor Head's Avatar
27 Oct 2012 15:10
#556020
I suggest getting a Service Manual for your bike!
Also if you state KZ750L3 as the model, it is an in line 4 and not a twin, completely different to do the starter clutch.
Sprocket cover and stator cover, and pull the rotor to access the starter clutch.
27 Oct 2012 18:43
#556032
Here's info on the KZ650 starter clutch repair. I don;t know that is is identical, but I believe if not it is very similar:
forums.kz650.info/index.php?action=dlatt...pic=586.0;attach=873
forums.kz650.info/index.php?topic=5152.0
  • Jesper
27 Oct 2012 19:17
#556037
It's a kz750r or Z750L3
Got a Haynes for it.
  • gengomerpyle
  • gengomerpyle's Avatar
27 Oct 2012 20:43
#556042
i need to do the same thing to my 750R.
Jesper wrote: It's a kz750r or Z750L3
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
  • Calico
  • Calico's Avatar
29 Oct 2012 11:32
#556212
Year?
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
  • Jesper
29 Oct 2012 12:09
#556215
L3 i a 1983 model.
  • Calico
  • Calico's Avatar
01 Nov 2012 15:36
#556689
Wow, I'm glad I checked back. Usually this site e-mails me on responces but whatever. Ok, cool bike! Pretty much the same set up as mine. So, have you removed anything yet or are you in the parts ordering phase? Other than the rebuild kit for your starter clutch, you'll be needing an oil pan gasket, clutch cover gasket, a couple of larger than normal sockets, an impact wrench, a torque wrench that reads low inches (harbor freight tools carries them cheap). Also, if you are due for an oil change, now will be the time to acquire the filter and oil. 1 more thing to consider; if you'ver heard a bunch of slack in your cam chain, you may want to look into a manual chain tensioner. I find them for about $50. If you need part contacts, just ask.
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
  • Jesper
02 Nov 2012 18:33
#556837
Have all the parts. Oil pan and sidecovers are off.
Next step is to fabricate a clinch holding tool, and then it looks like an easy fix
  • gengomerpyle
02 Nov 2012 20:25
#556841
well when you get done with yours you can come over here and do mine :)
1982 GPZ750R1 ELR
1971 Honda CB750K
  • Jesper
03 Nov 2012 06:21
#556911
Sure. If you want to pay for the ticket
