Z750L3/KZ750R starter clutch
- gengomerpyle
Re: Z750L3/KZ750R starter clutch
03 Nov 2012 10:22
lol
Jesper wrote: Sure. If you want to pay for the ticket
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
- Calico
04 Nov 2012 12:00
I just used shop rags. You can trap a strong coin in the gear behind the basket.
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
- Jesper
25 Nov 2012 12:59
An update.
Clutch and clutchbasket is off, and so is the oil pump.
As far as i know, next step is to tap the shaft and starterclutch from the left side, så the bearing on the right side will come out. But no.
The shaft is loose, and I can tap it from side to side, but the right side bearings dosn't come out. So have to solve this one.
25 Nov 2012 13:10If needed, this link is to a site that includes a free down-loadable service manual, that may help with the procedure involved.Jesper wrote: An update.
After accessing the site, scroll down to and click on "The Bible."
First, click > kz.bike-night.com/
- Jesper
09 Jan 2013 17:43
Got the starterclutch out. Bit tricky at first.
One of the springs where broken, and the roller was stuck.
Fitted ned springs and rollers, and got it back in the engine. Did it with the engine in the frame, and it was quite easy to put it back together.
Now I just need to fit the exhaust and give the engine a service, and its ready to get back on the roads.
09 Jan 2013 17:54
I saw that getting the right side bearing out was difficult. Did tapping the shaft finally pop it out, or did you need to do something else to remove it? Ed
- Jesper
10 Jan 2013 02:55
I removed the nut, and took the starterclutch apart while it was still i the engine. Getting it back in was the same.
Fitting the clutch to the chain, and then sliding the shaft in.
