- Thank you received: 2
What piston kit to go with?
- sc/ant864
18 Oct 2012 00:06 #554441
by sc/ant864
kzrider.com/forum/11-projects/543276-77-...543286]'77KZ900-1000 streetstrip project
'77KZ900/1000
'89BMW E30 325i sedan
'88Mustang GT
'77Datsun PL620 KingCab
George Carlin- "I often think how different the world would be if Hitler had not been turned down when he applied to art school."
What piston kit to go with? was created by sc/ant864
So you guys that have followed my threads know I've pretty much given up on using my mismatched,scuffed up pistons but now I have a dilemma. Should I go with a larger displacement and have my cases opened up or go back with another set of 900 sleeves and 1015 pistons? I don't want to have to do head work other than a valve job and new seals and keepers, so if I go with say a 1045 kit(being able to bore later to 1075 is a plus too), will the 900 head which was ported heavily be able to handle the extra cc's? Cost-wise it seems there isn't much difference between most of the kit's from 1045 till you get to 1100cc and need a big block. I was hoping to go to a 1045 with my stock sleeves but I've seen conflicting posts on it and I live in the deep south so hot weather is unavoidable. Basically I'd like to hear a few more opinions on what I should go with.
'77KZ900/1000
'88Mustang GT
- wireman
- Thank you received: 299
18 Oct 2012 01:08 #554450
by wireman
Replied by wireman on topic What piston kit to go with?
Id go ahead and find a decent kz1000 block and sleeves and have the cases cleaned up to fit them,then you can run a 1015-1075 without having to go back into the bottem end again later.
The 900-1000 heads use the same ports from 73-80,no big advantage in either head other than bigger exhuast studs on the kz vs z1
- APE Jay
- Banned
- Thank you received: 58
18 Oct 2012 01:40 #554455
by APE Jay
Replied by APE Jay on topic What piston kit to go with?
You don't need a big block until 1327cc. You didn't say if the head had stock size valves. If not, it couldn't have too heavily ported.
However, with 1015 or 1045, you should be good.
- sc/ant864
18 Oct 2012 07:44 #554466
by sc/ant864
'77KZ900/1000
'88Mustang GT
Replied by sc/ant864 on topic What piston kit to go with?
Valves are 36mm intake/30mm exhaust, thanks for the replies and suggestions.
'77KZ900/1000
'88Mustang GT
- LarryC
18 Oct 2012 08:17 - 18 Oct 2012 08:21 #554470
by LarryC
Those are stock size. Adequate for a 1015 but not ideal. They were correct for the 900 motor. Kawasaki should have gone to 38's when they made the motor 1015. The 30mm exhausts still would have worked just fine.
Measure the throats. Not the runners. The throat is the opening where the port meets the seat. That should be at least 32mm. If it's not, open it up.
If you have any doubts on the sleeves, go 1015. Bolt together what you have and go enjoy the bike
Larry C.
Replied by LarryC on topic What piston kit to go with?
sc/ant864 wrote: Valves are 36mm intake/30mm exhaust, thanks for the replies and suggestions.
Larry C.
Last edit: 18 Oct 2012 08:21 by LarryC.
- sc/ant864
18 Oct 2012 09:16 #554476
by sc/ant864
'77KZ900/1000
'88Mustang GT
Thanks Larry, Jay and Wireman. Once I get a valve compressor I'll post the runner numbers.
'77KZ900/1000
'88Mustang GT
