- Thank you received: 13
Too Tight Cam Chain
- Garn
RegardZ.
PS. Just had another thought.... LONG- shot!.....Perhaps the sprocket idler with the chain adjusting wheel hanging from it, is mounted the wrong way around ..... causing the chain to have tension!..... LONG SHOT!
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
- LarryC
Garn wrote: Take both cams out! Hold chain, and rotate engine see if chain hasn't bunched in the bottom plumbers block as others have suggested. Good idea ApeJay .... check the package the chain came in!
RegardZ.
I've seen that happen. It's worth checking, considering the intake cam is rocked back.
A couple of things in the picture are hard to see clearly. In particular, the index mark for the exhaust cam. I see what looks like 2 possible marks but one looks like it's been scribed by hand. It's the one indicated by the yellow arrow in the pic.
What looks bad is it's too high above the valve cover surface.
There's another mark, not easily visible unless you blow up the pic. It's indicated by the blue arrow in the pic. It's more correctly oriented in relation to the valve over surface. If that one is the factory index mark, then the pin count is off by 1 pin.
However, it doesn't explain the lack of slack. If the pin count is 29 vs 28, there should be plenty of slack in the chain between the cams unless there's a problem elsewhere.
Attachment exhaustindexmark.JPG not found
Larry C.
- Garn
regardZ.
Sydney Australia
- 3cav84a
- Thank you received: 3
1977 KZ 1000 A1
- BB
Well, I installed a 120 link chain as any good mentally challenged rookie would do. I wont mention the company I ordered from, but needless to say, I wont be using them again.... They sent me the wrong chain, I didn't check, these things happen.. Good practice at splitting the cases, I have the 124 link chain installed and she fits well, it is really tight, but turns nicely.
One thing, I stripped a thread in the #1 cam cap. What is the best way to repair this, a buddy mentioned some sort of device you would insert in the drilled out thread? any thoughts?
Thanks for all the help guys, much appreciated. Sorry for the delay in responses - this work thing sure gets in the way of bike rebuilds..
Cheers, Brendan.
1980 KZ1000P - The Mistress
2002 R1150GS - Matilda
- Thank you received: 2064
Look up Helicoil for thread repair and follow simple instructions
Their is more than one manufacter of helicoil type products depending on where you are. Best done off the bike to insure proper alignment of drilling so more damage is not done.
Good Luck
- Thank you received: 2829
Timesert for thread repair:
www.timesert.com/
In the future use a torque wrench calibrated in inch/pounds to prevent stripped threads.
- elfmagic17
- Thank you received: 24
650ed wrote: 2 suggestions:
www.timesert.com/
X2
Timesert is the BEST choice, it's like installing steel nuts in the aluminum.
Kenny Hicks
74 Honda CB550
- APE Jay
- Banned
- Thank you received: 58
However, The KZ takes the peanut style chain like in Larry's photo above. I don't even know of any KZ that takes a 120 link chain.
120 is the standard Suzuki GS1000/1100/1150 size, but they are a flat side plate style.
We don't even stock a 120 peanut chain. Not sure where you would get one if you needed one.
- Garn
An easy mistake to make by buyer or vendor.
RegardZ.
Sydney Australia
