wont start in the cold
- tailpipe51
- Horsepower Addict
05 Oct 2012 13:22 #552612
by tailpipe51
1981 KZ100J Maroon
V&H header with 45 degree turn out for exhaust
Fairing, quater fender and saddle bag removed
Repainted side covers black
repainted frame black
NGK spark plugs
Runs but not driven yet
1993 GMC Suburban 4x4
straight piped accel ignition
cutsom intake
visor
mudflaps
undercoating...
wont start in the cold was created by tailpipe51
its about 40 degrees here in waterford and my bike wont start could it be because its cold out or could it be something else????
1981 KZ100J Maroon
NGK spark plugs
cutsom intake
visor
mudflaps
undercoating...
- Del_Herring
- Thank you received: 29
05 Oct 2012 13:49 #552622
by Del_Herring
1983 KZ750-N2 Spectre
Replied by Del_Herring on topic wont start in the cold
40 degrees might make it a little harder, but shouldn't keep it from starting. Using full choke, and no throttle? (the 1000's don't use a true choke, and if you give them throttle it bypasses their mechanism for it). Is it at least sputtering like it's trying to start and just not catching? Or is it doing nothing at all?
- tailpipe51
- Horsepower Addict
06 Oct 2012 12:22 #552751
by tailpipe51
1981 KZ100J Maroon
NGK spark plugs
cutsom intake
visor
mudflaps
undercoating...
Replied by tailpipe51 on topic wont start in the cold
It was trying to start it started when I tried it last night
1981 KZ100J Maroon
NGK spark plugs
cutsom intake
visor
mudflaps
undercoating...
- Motor Head
- Thank you received: 391
06 Oct 2012 12:29 #552754
by Motor Head
Replied by Motor Head on topic wont start in the cold
Your signature says, "Runs but not ridden yet"
So you just got the bike?
You carbs are most likely plugged up from sitting, or you have vacuum leaks.
Low speed circuit, and starter jet circuit are quite small and easily plugged up with crud.
- tailpipe51
- Horsepower Addict
07 Oct 2012 15:35 #552926
by tailpipe51
1981 KZ100J Maroon
NGK spark plugs
cutsom intake
visor
mudflaps
undercoating...
No I have had it for a year now it just got passed down from my stepdad 2 me I havnt gotten a chance 2 ride it yet
1981 KZ100J Maroon
NGK spark plugs
cutsom intake
visor
mudflaps
undercoating...
- Del_Herring
08 Oct 2012 11:46 #553066
by Del_Herring
I'm with motorhead on this. Sounds like a good carb cleaning is needed. And then, if you have vacuum leaks, maybe some new carb holders.
- Jeff.Saunders
08 Oct 2012 13:16 #553080
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic wont start in the cold
It is more down to a weak spark.
Check the voltage across your battery terminals and you should have 12.5v or more with a good fully charged battery. Then check the voltage at the coils. I think it's a yellow / red wire that's the switched power feed going to the coils. With the igntion switch on and the kill switch set to run, put a probe in the connector and take the other end back to the negative on the battery. You need better than 11v to get a quality spark - ideally better than 11.5v. DOn't leave the igntion on for more than a few seconds - it can overheat the coils.
Cleaning the contacts on the connector blocks, bullet connectors etc may get this back - if not, there's a last ditch approach the requires a relay get inserted in the circuit - do a search for coil relay mod on this forum for details.
Z1 Ent on Facebook,
