compression of 81 kz1100
- kzcafer
29 Sep 2012 23:42 #551619
by kzcafer
compression of 81 kz1100 was created by kzcafer
how much compression should each cylinder show.. thanks
- Motor Head
- Thank you received: 391
30 Sep 2012 00:04 #551621
by Motor Head
Replied by Motor Head on topic compression of 81 kz1100
Download the pdf service manual in my signature, it will have the info for you. Keep in mind to open the throttle during testing, also that altitude will lower the reading. So I would do a dry test, then a wet test, where you add a small amount of oil to the cylinder being tested.
- daveo
- Thank you received: 655
30 Sep 2012 16:29 #551707
by daveo
1982 KZ1100-A2
Replied by daveo on topic compression of 81 kz1100
My last two compression checks were 165+/- across the four.
1982 KZ1100-A2
