- Thank you received: 4
KZ1000P; resonance at 4K RPM normal?
- imon_2nd
- Architect & Engineer
29 Sep 2012 20:31 - 29 Sep 2012 20:31 #551588
by imon_2nd
Keepin' the rubber side down.
KZ1000P; resonance at 4K RPM normal? was created by imon_2nd
Hello, all.
I'm really enjoying my 1997 KZ1000P. It is close to 100% restored and I've been commuting 25 miles each way every day as often as possible. One thing that seems odd: At exactly 4,000 RPM in any gear the engine vibration "rings" the whole bike. By 4,300 RPM the buzzing is gone completely. At all other engine speeds everything is vibe-free. I don't remember this being the case on the Z1 900cc bike I rode years ago. Is this vibe point typical for the KZ1000? Should I be looking for a problem somewhere in the motor?
Cheers,
Cheers,
Last edit: 29 Sep 2012 20:31 by imon_2nd.
- RonKZ650
- Thank you received: 240
30 Sep 2012 01:35 #551632
by RonKZ650
Replied by RonKZ650 on topic KZ1000P; resonance at 4K RPM normal?
They have the rubber mount engine setup that reduces vibrations, but also causes a certain place where vibrations are more. It's been a long time since I had a rubber mount engine, but remember certain RPMs where vibes were pretty bad.
- blipco
- 2002 KZ1000P
- Thank you received: 223
30 Sep 2012 16:25 - 30 Sep 2012 16:27 #551706
by blipco
Replied by blipco on topic KZ1000P; resonance at 4K RPM normal?
I have an '02. I am not getting any sympathetic vibration at any RPM. I steepened the gearing by going down 4 teeth in the rear for a gearing of 17/42 (I didn't notice any before the change either). This has calmed the motor at highway speeds. It was part of my project to increase gas mileage.
Last edit: 30 Sep 2012 16:27 by blipco.
