Release Chain tension?
- built408
1978 KZ1000 A2A with MKII body you know you like it
- wireman
- Thank you received: 299
- built408
- wireman
- built408
- Powerstroke_fan
- Thank you received: 83
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- wireman
Ok remove short bolt and nut from side of tensioner then push plunger back in all the way and screw longer bolt in to temporarily hold the plunger .
Install tensioner with new gasket back onto motor then remove long bolt from side of tensioner to let plunger pop back against guide inside of motor.
reinstall short bolt and nut.
Then using the bigger nut on the advance mechanism under points cover turn the motor over repeatedly(I reccomend pulling spark plugs out myself)to make sure nothing is binding before trying to crank motor with starter.
Id explain how you can convert the auto tensioner to a manual set up using your stock pieces and $5.00 worth of parts from ace hardware ,but between stroking my ego / trying to cure world hunger fixing stuff all I have time for is vague answers to questions that would require a person to read a manual for 5 minutes to answer for themselves! :woohoo:
- 893cv
- Thank you received: 15
built408 wrote: Ya I do but I wanted some advice. Isn't that what this site is for or just a bunch of ego strokers? I always get lame vage responces.
1980 kz1000 LTD
1978 Z1R
- kzz1king
- Thank you received: 52
wireman wrote: Wow,ego strokers? :woohoo:
Home built KZ1000 turbo setup
- Thank you received: 2829
I took a look at your previous postings and frankly it looked to me as if you always received very good, specific responses. Did I miss something? Ed
- wireman
Thats only on carb gaskets,id spray copper coat on both sides of the tensioner gasket.kzz1king wrote: AND put chapstick on said gasket :woohoo:
- KraZyRIDER
- Thank you received: 44
...wow!
...just, wow! :blink:
Mean Green Speed Machine!
1979 KZ 650-C3 (Cafe Project)
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
