Clutch won't engage after changing handlebars
- Lddemi
Where can I go from here? Many people have suggested removing a sprocket cover, but I have no idea what that would be on my bike. I feel like I have a different clutch setup than anyone else.
Also, does my bike have a clutch pushrod adjustment feature? I've heard mention of using that to adjust the clutch.
1984 Kawasaki KZ550 LTD Shaft
- Powerstroke_fan
- Thank you received: 83
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- trianglelaguna
- Thank you received: 235
not a big deal and it may take a re-do again to get it just right but once you know the procedure it is a snap
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- DiamondSkyBlue1000
- Thank you received: 40
First, make sure there are no sharp bends in the cable or that it's going to get caught on or bind up on any part of the bike while you are riding it.
On the clutch cable there is usually an adjustment in the middle of the cable also but that may not be the case since your engine has that lever setup shown in the picture.
When you say loosened up the the adjuster at the handlebar, did you turn the adjuster wheel so it moved further away from the lever? That makes the cable tighter. To loosen it, turn that wheel all the way until it is tight against the lever perch. If you have an adjustment midway on the cable itself, make sure that the pieces are threaded in as close to each other as possible, that loosens the cable also.
Once you get enough slack to let the clutch fully disengage, then you use those adjustments to set where in the handlebar lever movement you want the clutch to engage/disengage.
- steell
Look in the middle of the cable for a screw adjustment, it may be pulled out and stuck on the edge.
- Lddemi
DiamondSkyBlue1000 wrote: When you say loosened up the the adjuster at the handlebar, did you turn the adjuster wheel so it moved further away from the lever? That makes the cable tighter. To loosen it, turn that wheel all the way until it is tight against the lever perch. If you have an adjustment midway on the cable itself, make sure that the pieces are threaded in as close to each other as possible, that loosens the cable also.
That was exactly what I needed. Loosened her up and everything works nicely.
Does anybody know if there's a way to loosen the throttle cable on my bike from the carburetors? It's fully loosened on the handlebars but my bike still idles a little bit high.
- Thank you received: 2098
On many models, throttle slack adjustments may also be done at the ends where they attach to the carbs.
- Del_Herring
- Thank you received: 29
So, if you don't have any slack, give it some using the other adjuster on the cable on the carb side, if you have slack, and still idle high, use the idle adjustment. Not sure where it's located on your bikes, but typically they're in the middle of the carbs, and adjustable by hand, or with a small screwdriver.
1983 KZ750-N2 Spectre
- Lddemi
Could be a vacuum leak, dirty carb internals, poor synchronization, needing a tune up, and on and on...
But, let's get that throttle cable sorted out. That's a big safety concern.
- Lddemi
Edit:
Here's how the bike looks now for the curious:
Just need to do something about that seat........
