GPZ 750 engine in KZ 750 swap
- pinkiedog64
27 Sep 2012 15:01 #551183
by pinkiedog64
GPZ 750 engine in KZ 750 swap was created by pinkiedog64
Hello all,
I am new here. I've had a 1980 KZ 1000 and now have a 1982 KZ 750 E model 4 cyl. I am very comfortable with working on engines and repairing things myself. There is a local guy selling an 84 GPZ 750 engine. My question is, besides from electronics and carb, does the GPZ 750 engine bolt right in where the stock engine does? Current engine needs a head gasket and could use a rebuild and I'm thinking $275 for a running used engine is more worth it than rebuilding the stock motor. Any input is appreciated.
Thanks, Stephan
Thanks, Stephan
- Del_Herring
- Thank you received: 29
27 Sep 2012 15:41 #551195
by Del_Herring
1983 KZ750-N2 Spectre
Replied by Del_Herring on topic GPZ 750 engine in KZ 750 swap
I don't know of any differences. To my knowledge, the block and heads are the same, so all the mounts should be the same. Definitely check out Kawasaki.com for parts diagrams to see if it shows interchangeability for the two. Would just need to check the crankcase and heads. If they're shown as interchangeable, you're good to go. May also check output shafts on them to determine if you'll need an offset sprocket, but I'm thinking it should be a straightforward swap.
- steell
27 Sep 2012 15:43 #551196
by steell
Replied by steell on topic GPZ 750 engine in KZ 750 swap
You will have to use the GPz750 offset sprocket to make the chain line up, unless you put the KZ750 trans in the GPz750 motor. Mounts all line up, but you may have to use washers on the front mounts since they are rubber mounted in the GPz750. If the alternator wires don't plug in the easiest fix is to use the KZ750 stator, rotor, and cover. Don't waste your time trying to wire up the GPz750 ignition, just swap in the 750E complete ignition.
I think that about covers it.
- zukdave
- Thank you received: 229
28 Sep 2012 21:17 #551479
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Replied by zukdave on topic GPZ 750 engine in KZ 750 swap
I run the Gpz ign. on my swap
Use the factory harness,
red wire from the igniter to key on 12 v.
Ground the black and the brown wire's your done.
Then the motor has the factory timing curve.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- apeman
- Thank you received: 3
01 Oct 2012 23:29 #551907
by apeman
Petaluma and Truckee, CA -- member since Jan. 23, 2003;
PREVIOUS KZs: 1980 KZ750H with 108,000 miles; 1980 KZ750E with 28,000 miles; and KZ750H street/cafe project, all sold a few years back.
This is what I do for fun, not for work. It is art, with a little engineering thrown in.
Replied by apeman on topic GPZ 750 engine in KZ 750 swap
Not certain, but some of the later model 750 engines have a different clutch operating mechanism. You might need the connecting bits from the GPZ.
- zukdave
03 Oct 2012 00:10 #552138
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
I used the gpz clutch cable that was on the doner bike
worked fine at the hand lever
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- steell
04 Oct 2012 19:27 #552467
by steell
If you use the GPz750 Mikuni carbs you need to use the GPz750 throttle cable also.
- zukdave
05 Oct 2012 21:54 #552685
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
I'm set up with VM29's, single cable and
a Motion pro 1/4 turn throttle.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
