Curious ticking..
  • brianrae33
  • brianrae33's Avatar Topic Author
Curious ticking..
26 Sep 2012 10:59
#550980
recently reringed bike and head cylinder head completely rebuilt..question...upon initial startup all is normal..but when bike reaches operating temp it develops a very slight ticking from the top left side of engine..never gets any louder but is fairly constant..could valves need adjusted so soon after a rebuild? And if it is a valve is there any danger of doing damage from riding it?? Like i said very slight tick..most people probably wouldnt notice unless i pointed it out..just curious..thanx in advance..
1982 kz1000ltd
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: Curious ticking..
26 Sep 2012 13:06 - 26 Sep 2012 13:16
#550998
Ok....seems to me the valve clearance could be off...have you checked these and if so what are the numbers.....have you done a compression check? did you install new valves?? On riding the bike with noise....Any tic is a sign of a problem. A healthy engine shouldnt tic....you need to be concerned and actively hunt this issue. I wouldn’t blow it off....Spencer
Last edit: 26 Sep 2012 13:16 by 4TheKZ1000.
  • OldSchoolZ
  • OldSchoolZ's Avatar
26 Sep 2012 14:21
#551003
Exhaust leak at head can also make that same sound. Check bolt tension and exhaust gaskets before going to far. ;)
Remember, don't work on your bike so much you never ride it.
The following user(s) said Thank You: BlackZ1R
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
26 Sep 2012 17:18 - 26 Sep 2012 17:20
#551026
i would check for a exhaust leak. like oldschoolz said
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Last edit: 26 Sep 2012 17:20 by Powerstroke_fan.
  • 4TheKZ1000
26 Sep 2012 17:54
#551033
OldSchoolZ wrote: Exhaust leak at head can also make that same sound. Check bolt tension and exhaust gaskets before going to far. ;)
+1 Yep, this could be it.
  • bountyhunter
  • bountyhunter's Avatar
26 Sep 2012 18:15
#551037
If it's an exhaust leak, it will get louder if you crank open the throttle.
If it's a loose valve, it probably won't hurt to ride it but check it anyway.
  • boyd825
  • boyd825's Avatar
  • Ride it like you stole it!
26 Sep 2012 18:30
#551042
Check the cam chain tensioner,too.
1977 KZ1000 A1
  • bluej58
  • bluej58's Avatar
26 Sep 2012 21:04
#551067
I have a little tick in the left top end , had it for a while, twenty + years :woohoo:
It goes away when it warms up.
Note: it hasn't been rindin since 92
I know it's not the valve clearance , they're right where we're suppose to be.
Maybe somethings sticking :huh:
Maybe the exhaust ?
My plans are to pull the motor this winter and after a bit of work go with my spare motor.
If that works out it will be time for a top end job on the old girl
78 KZ1000 A2A
  • brianrae33
27 Sep 2012 11:29
#551148
90% sure it is not an exhaust leak..vlves are not new but had three angle valve job done and new bronze guides..place that rebuilt head is pretty reputable..runs great just a little tick..i've heard the old kz engines are prone to engine noise when warm..maybe just being paranoid..
1982 kz1000ltd
  • daveo
  • daveo's Avatar
  • Premium Member
28 Sep 2012 12:34 - 28 Sep 2012 16:17
#551358
Mine was ticking til last night when the tick suddenly got worse. Fortunately I was a block away from the toy box, after a thoroughly exhilarating ride.
I thought a bad exhaust gasket, but still there after replacing the set. And the engine has lost it's K-Zam.
The compression in #2 is now 150-155, vs. 165 across all prior.
I'm thinking it was a sticky valve that got a little bump.
Man, I dread the thought of pulling that head off again. But, it will likely come to that.
False alarm...whew! :whistle:
1982 KZ1100-A2
Last edit: 28 Sep 2012 16:17 by daveo. Reason: not problem...
28 Sep 2012 13:53
#551384
daveo wrote: Mine was ticking til last night when the tick suddenly got worse. Fortunately I was a block away from the toy box, after a thoroughly exhilarating ride.
Would not pull the head until first performing back to back compression tests to compare dry test with wet test.
And also performing a leak-down test.
Would double-check tightness of exhaust clamp nuts, and fitment and condition of the exhaust clamps, to assure no loose nuts or cracked or broken clamp.
And also double-check the valve clearances.
And assure oil is reaching the top end as it's supposed to.
And clean fresh oil at proper level. Plus a fresh clean oil filter.
Good Fortune! :)
  • blipco
  • blipco's Avatar
  • 2002 KZ1000P
28 Sep 2012 15:09
#551398
Could it be a slightly bent valve that ticks when it rotates a certain way? According to a long time KZP mechanic (from another site I belong to) there can be a slight tick that comes and goes. He never found out why as no police department was willing to tear down a good running engine to find out (if it ain't broke don't fix it type of thing). The rotating bent valve stem theory was his idea.
