- Thank you received: 2
Ring Seating
- lemo32
- The Price of Cool aint cheap
1979 kz 1000 06 katana 750
- lemo32
- 4TheKZ1000
- Visitor
Did you gap pistion rings to the cyclinder.
Did you stagger piston ring gaps thoughout the cyclinder.
Is the cam timing correct...if not compression will leak out valves.
Did you adjust the valve clearance correctly and recheck.
- lemo32
- wireman
- Thank you received: 299
How did you clean the bores before putting motor together?
- Garn
- Thank you received: 13
The rings have to bed into the bore, that's where the cross-hatch pattern on the honing comes into play. Give it about 20 miles or so and I'm sure it will improve.wireman wrote: Put some miles on the motor and recheck.
RegardZ
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
- Polar_Bus
- Thank you received: 7
Bikes:
'84 GPz1100
'06 HD Fatboy
- LarryC
Polar_Bus wrote: I had to do some ex valve guide repair on my Gpz about a year ago, and I decided it would be smart to re-ring while the head was off. My mechanic commented I will need about a good 1500 miles for the rings to seal. He was right, I burned a lot of oil the first 700 miles or so, and now i'm up around 1200 miles, and the oil burning is definately lessening.
:whistle: That's not good.
Larry C.
- Bozo
- Ride it like u stole it
- Thank you received: 105
If this is your case, re hone and put new rings in, when I found the problem I thought just turning the rings would be ok, it never was, just used oil and the power was down. Hope this helps.
- Motor Head
- Thank you received: 391
Did you do a Valve job? Or head work of some kind?lemo32 wrote: yeah, all the above, staggered rings, checked gap, checked piston in bore via feeler guage, all that checked out, also adjusted valves to within .004 on all cyl, did leakdown not leaking at valves, so must be bottom end.
The Leak Down Test you did, was it with gauges? If so what percentage Held out of 100 psi input?
While compression should come up with rings seating, it sounds as though you are low anyway. Did you check it with a second compression gauge, as its possible to have one read low. Are you far above sea level, as this will effect readings?
- steell
Valves, cam timing, or something else in the head.
