- Thank you received: 1
Carbs and cams
- baborz72
- Not enough hours!
It'll go...or...It'll blow!
- wireman
- Thank you received: 299
- baborz72
- Not enough hours!
- wireman
Carefull with that sidewinder pipe,many of them wont clear a stock unraked front end and could jam the wheel between pipes in a corner or hard braking
- baborz72
- Not enough hours!
- wireman
Other than that Ive never had a front end issue with 30 plus years of pushing these things harder than most anyway.
- Old Man Rock
- Thank you received: 225
Translation: Need the air intake for all the combinations to work for desired performance.
Contact Larry C, he'll be able to explain it fully on what combination (Valve sizes, porting. cams etc...) would work better for your desired results.
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- 4TheKZ1000
- Visitor
wireman wrote: That depends entirely on the track location and rider.
Will also mess with the rear brake pedal. Most time have to mod it.....also might need a rear mount fabed for the megahone.
Attachment bike034.JPG not found
- mtkawboy
- Thank you received: 16
- baborz72
- Not enough hours!
- baborz72
- Not enough hours!
- wireman
Hell you can run your bike at topeka kansas then run it up to eddyville iowa and run it the same day and not run the same time!
Anybody whos ever spent any amount of time racing whether its a bike/boat/car or a turtle will tell you the same thing. :laugh:
