More issues. '82 1100A
- LarryC
16 Sep 2012 09:56 - 16 Sep 2012 10:26 #549019
by LarryC
Put a good healthy amount of blue locktite on the bolts. Make sure you spray out the holes with contact or brake clean. PAY ATTENTION here before you get sent on a while goose chase by people that never touched one of those bikes....geesh, I see this shit all the time on here....
ala Jimmy Buffett
Pull the spark plugs and see if they're oily. You may or may not have carb issues. Hopefully, all it needs is a good carb cleaning. If you have spark on all 4, that rules out the ignition.
Was the smoke blue or black?
J heads are prone to sinking valve guides. That can show up as blue smoke out the pipe. If it's continuous, it needs to be addressed. If it's only on start up, you can probably get by for a while.
If the exhaust is pulled, you can shine a light into the exhaust ports and clearly see if any guides are protruding down further than others. Same deal on the intake side with carbs removed but you'll have to use a mirror to see the 2 inside ports clearly.
Larry C.
Replied by LarryC on topic More issues. '82 1100A
pickardracing wrote: Looks like the 3 mounting bolts for the starter clutch are FUBAR. Z1 doesn't list them, am I screwed with having to go to the dealer? They have 12.9 stamped on them so I'm assuming a regular grade bolt won't do the trick.
ala Jimmy Buffett
Larry C.
Last edit: 16 Sep 2012 10:26 by LarryC.
The following user(s) said Thank You: pickardracing
- pickardracing
- Thank you received: 1
16 Sep 2012 13:50 #549070
by pickardracing
Current: 1982 KZ1100 A2
Past: 1980 GS750L - 1978 GS1000 - 1978 GS750
1983 GS750 - 2001 ZRX1200R - 2001 YZF-R6
Replied by pickardracing on topic More issues. '82 1100A
Smoke is a blue/white. It may have been over filled.
- wireman
- Thank you received: 299
16 Sep 2012 14:02 #549072
by wireman
Replied by wireman on topic More issues. '82 1100A
Even if it was over filled it would have to leak into combustion chamber past a guide/valve or rings depending on when /how much it smokes.
