- Thank you received: 1
More issues. '82 1100A
- pickardracing
Spent a bunch of money on plugs, wires, caps, etc. Went through the entire wiring harness, cleaned every connector alive with de-oxit. Everything has good voltage, spark looked good, compression tests came out fine, I'm lost.
There's no reason (other than carbs) that this piece of $#!t won't run. Started decently, but smoked like a damn chimney on startup out of the LH muffler. Go ahead and watch the video. That's the noise it makes in the engine when running, and it will absolutely not idle or run below 1500rpm.
Any ideas or help would be fantastic. If I can't figure this out, I'll likely just part it out to get my money back and say eff it.
Thanks guys.
Current: 1982 KZ1100 A2
Past: 1980 GS750L - 1978 GS1000 - 1978 GS750
1983 GS750 - 2001 ZRX1200R - 2001 YZF-R6
- P21
- Thank you received: 34
sounds like slow jets are bound up.
1500 rpm down is controlled my them
Kawasaki KZ 1000 Police (2002) P21
- Thank you received: 2098
- pickardracing
Would carbs cause this ridiculous smoking and noise? I mean I understand that they'll cause all sorts of issues, but heavy smoke and sounding like it's going to shit the bed?
- pickardracing
- MFolks
- Thank you received: 540
- pickardracing
- wireman
- Thank you received: 299
My speakers dont work on my computer so I couldnt hear your video but once you get the starter clutch back together it definately wouldnt hurt to clean/scrub carbs out if its black smoke rolling out your exhuast when you start it id guess fuel.
As long as youre in there pick up a valve cover gasket and check valve clearances,a cylinder with a valve hanging open would be tough to start also and would need a higher idle to compensate for lower compression to keep it running
- wireman
Bolt depot shows those bolts for .23 each on their site.
- Del_Herring
www.engineeringtoolbox.com/steel-bolts-m...c-grades-d_1428.html
www.engineeringtoolbox.com/steel-bolts-sae-grades-d_1426.html
think it actually works out a little stronger than a grade 8, but same idea. If it's a standard bolt size (sometimes you get lucky), you can pick up 12.9 class bolts at an Ace Hardware, or equivalent.
1983 KZ750-N2 Spectre
- MFolks
- LarryC
MFolks wrote: Some engines have a woodruff key on the alternator shaft, preventing the rotor from spinning. The key resembles a half moon shape with a machined slot in the crankshaft where the rotor goes.Others are nothing more than being held on the shaft with the torque from the rotor bolt.
Kawasaki quit using that setup in 79. It helps if you've actually worked on bikes that you post tips on how to fix
Larry C.
