- Thank you received: 47
Oil
- BlackZ1R
- Kawasaki in my blood
Nothing like an oil thread huh? I've been using a different oil lately.
Has anyone used Mobil Super 5000 10w/40 in their bikes. Looking at the website there are no friction reducing additives and is NOT Energy Conserving oil that you don't want to put in your bikes.
FWIW, I put this in my KLR650 the last oild change and it actually shifted better and doesn't seem to "use" as much oil as it did with Rotella 15w/40. :whistle:
Any down sides I'm not seeing?
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Powerstroke_fan
- Thank you received: 83
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- Tomolu5
- Thank you received: 45
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
- bountyhunter
- Thank you received: 337
It'll work fine as long as you don't run it past maybe 2500 miles service limit.BlackZ1R wrote: Ahh, not this &^%$ again... :laugh:
I would recommend adding ZDDP.
- LarryC
Now if there were some way to tie oil and BS34's together into the same argument :woohoo:
Larry C.
- BlackZ1R
You talking something like STP or an oil treatment dealio?
Kawasaki
- bountyhunter
I buy ZDDP in a product called ZDDPlus but STP does have a good amount of it. Stp will raise viscosity about 5 points, so it makes 10-40 look more like 15-45.BlackZ1R wrote:
- Thank you received: 1656
- baldy110
- Thank you received: 512
LarryC wrote: Where would the Internet be without an occasional oil debate?
OK, Larry here goes.
So I have this problem with my BS34 carbs. I filled them with 10-40 weight oil and now I can't get my bike to run. Any ideas.
- les holt
- Thank you received: 288
Les
- LarryC
That should work fine as long as you have pod filters. If not, switch to 20-50 and lift the needles :side:
As a side note, I just changed the oil in my ZRX to Kawasaki Oil. I swear the headlight and turn signals are brighter now...
Larry C.
